Xiaomi 14 Ultra
kiwizor
Did y'all buy the wireless charger? If so, how much?
Also, any thoughts on magnetic lens cap vs screw in? Thinking of getting magnetic but scared it slips off easily in pocket.
Just collected mine yesterday too, gonna play play this weekend.
mamboeidos
It got smart battery protection feature prevent overcharge and overheat. Got one problem with wireless charging though.. the thick and large circular camera island behind obstruct the optimal placement of the wireless charger.
That's why xiaomi comes out with that new retractable wireless charger
i see the 80w not cheap on TB... around 80SGD :eek:
SecretAgent
I use old circular shape Qi... I think is 50w... Still feels fast and under the constraints of thick casing and less than ideal placement of the charging pad position due to the big camera island.
Next thing I gonna test out is type C to HDMI displayport
See if this can really be a "simple" desktop.
caterham7
Where to get the best deal now ah?
Depends on what you mean by "best"
RedWhiteMobile and Challenger selling at RRP with free gifts camera grip and wireless charger. Contact them directly to check if deal is still available, free gifts usually while stocks last
Other shops may sell below RRP, but without the free gifts
dappercivility
Just wondering does anyone know if the Xiaomi 14 Ultra bundled case can fit lens filters? Lens filters usually come with screw threads instead of the click and turn kinda mounting system.
omae_wa_yowai
Got say like no say. :s13:
Hahaha but it's true~~ cause most shop not giving the photography kit after the PO period, if you want must wait for next time alr. If not is to buy from neighborhood phone shop for price discount.
I wanted to wait for price drop but my current phone cmi liao so I no choice also, else maybe can save $500++ by then~ hahaha
mamboeidos
does the 14u comes with pre applied screen protector?
if not will the screen get scratch easily?
SecretAgent
yes it does...
I still let it stick for a while until I really cannot tahan
so far... unless you are really rough and abusing the phone...the naked screen should be good for normal pockets under typical usage.
my old poco f3 naked screen is still good except for a very fine scratch for 3yrs.
the screen toughness technology should have improved since then.
dappercivility
Just to share, there is a 67mm ring adapter included in the photography kit. That ring can install a 67mm lens filter. Just got a cheap one and installed it.
SecretAgent
get those sparkling stars lenses if you like night photography
dappercivility
Lens Filter Installed, the phone gets really bulky with the camera grip as well as the Ring Adapter with the Lens Filter :LOL:
