Xiaomi 14 Ultra
DrMax88
Saw some users reporting lens fogging issue on Taiwan's mobile01 site. Have your guys experiened it?
MZeee18
Is it worth it to get the export set? I'm using pixel 8 pro and thinking about switching. T . T
rrr2015
I'm keen in photography
try demo set at xiaomi store see if it meet your photography needs.
export set usually means China ROM & seller warranty (i.e not official) & u need to install google system yourself though seller may offer to install foc. obviously there some risk for getting export set
dreamcast18
many comparison videos and reddit on it. Pixel has crazy good algos tho.
As mentioned..go try the 14U and see if you like it..the camera kit is definitely level up for photog fans..and its even better than the 13U version of the kit.
If you use filters etc..14U can't be beat. its a sweet camera with phone features..thats how i call it.
MZeee18
Anyone knows how to flash to eu rom or global rom? I considering export set cause more cheaper. Just worried for notifications
dappercivility
My opinion is, if there are official global sets available, I would go for that instead if the price difference isn't that much.
mamboeidos
anyone got this issue where the screen does not light up to the point that u thought the phone is not on?
now having this issue. no issue when woke up and reply msg. but after leaving home this happens.
the screen brightness for some reason was turn all the way down for some reason that's y
but even if all the way down should see something right even with screen protector.
crow_nest
Im on normal XM14, i cant seem to see Mi Smart Hub at all in my notif shade, even with it enabled in notifications. My xiaomi pad 6s pro can see it just fine, but i can never get the tablet to "see" my phone even with all the interconnectivity settings enabled and BT paired with one another. What's weird is my phone and tablet can pair via BT with the devices "saved" on one another, but it can never be "connected" via BT.
Those of you who got XM14U can enable Mi Smart Hub in notifications & status bar and let me know if its displayed in your notifications shade? I'm actually beginning to suspect its a ROM difference, cos my pad 6s pro is CN set using CN ROM, and my XM14 is local global set.
mamboeidos
for those purchase locally how to claim the free 3 month youtube premium ah?
I msg shopee xiaomi and they said just log in with your google account and you will have but I dont think it works this way and i have tried.
