Stable diffusion thread
kreja
Sorry noob here. What can SD do that is useful? I also want to learn leh. Where to start?
doogyhatts
We use SD to generate images. A lot of people are using it to create their AI influencer on IG and YT.
doogyhatts
So I found out that the quality output from AnimateDiff Lightning is actually lower for realistic animation, and it has a faint watermark.
It should be more suitable for cartoon visuals or non-realistic ones.
After further testing, I found out that the Multi-Diffusion upscaler in ComfyUI can help to improve the quality of the animation frames.
This is done before face fixing.
kgluong
Looks ugly. Like those placeholder game prototype from youtube tutorials
It's a very popular card game on steam.
The point is you save money. You don't have to hire artists. This is especially critical if you don't have millions dollars budget. For example fairlytale fable.
kreja
Hmm not very convinced but i guess AI art will continue to improve.
doogyhatts
Looks like results from the first few attempts on AniPortrait isn't very good.
In the meantime, I have tested the basic workflow for the SUPIR upscaler.
It can sharpen blurred images and only works on single images.
It is not temporal coherent across the animation sequence, details can flicker.
zheng
ai generate the card art?
doogyhatts
@order66
This channel did very well with just AI-cat images, but with a very catchy music track.
Music is likely to be created using Suno.ai. Just use "meow" in the custom lyrics.
kreja
Is there a way to replicate adobe image generative fill with stable diffusion?
doogyhatts
Yes, it is called outpainting. You can use Fooocus to do outpainting.
But the quality may differ from Photoshop.
