eb810v = APIf I buy the Firewalla Gold Pro what do you expect me to do with my current eb810v? BTW, the former don't have WiFi built-in but the latter has WiFi 7, FI, the Firewalla Gold Pro can have WiFi 7 support but later
eb810v = AP
i have no experience with tplink or it's products...Can I still use its 10G LAN port and the other 2.5G LAN ports? Like
ONT => Firewalla Gold Pro (router) => eb810v (AP) => 10G PoE managed switch => 10G unmanaged switch => PC/laptops and other devices
Router > switch > ap
your best bet is to download eb810v manual and read..What I want to know is can I still use the 10G LAN port on the eb810v (now set as AP) to connect to my 10G PC/laptop?
the question you should be asking is can you still use the 10G wan port on the eb810v
cos by right the 10G lan port is used to connect to the router in AP mode.
weird concern.What I want to know is can I still use the 10G LAN port on the eb810v (now set as AP) to connect to my 10G PC/laptop?
Using it as top layer gatewayActually, the purple like not bad also hor? For those who dun need >1Gbps...but the downside is only 1 LAN port out, so a switch is must...
Any idea if this will work with Unifi's switches?
which cpu? how's the fan noise?
TB don't have i5 variant in stock![]()
from ISP fiber --> Purple --> Unifi Dream Machine the capsule all in one with wifi--> AP
works well, just losing out on packet identification [ which i rather love unifi's way of doing things ]
attached some ss, from the macOS app, as you can see, i cannot see the devices that are behind the Unifi machine
was and am a supporter for their intial products [ Firewalla purple, used for travel but now have since been replaced by much better gl-inet for wifi only ]
For most of the interface , and extensibility, i believe firewalla may have a good niche market catered to, else they wouldnt have pushed for this kickstarter ish.
however,
pros :
- docker and all can be done, if dont correctly, its much better than what asusmerlin offers, when using adguard home and the likes.
- the above would also mean, any pi-hole can be done as well.
- purple only, its good for emergency wifi issues and troubleshooting, and its really pocketable
- has inbuilt ips./ids and its own set of adblocking rules
cons :
- have yet to test, in my own free time, its IDS /IPS properties
this means ive no idea, technically, what kind of underlying system program for those packet sniffing
- the forums, is mostly dead, because, it kind [ just works ]
- the way people correct or suggest solution, might be triggering even for edmw standards.
for those, who need a good all rounder security suite which can serve as site-to-site extension, and extensibility with docker, and fiber networking, seems like a good upgrade jack of all trades.
p,s best to post an official question on their forums and the page to get a solid answer in regards to port settings
first time I heard of gl-inet and I am sure u did your research, what makes u choose it over the rest?
does it work with hotel LAN connection which requires guest logins before they allow usage?
if choose between the gl-e750v2 and gl-xe300, which will u pick?
which model are u using?
double NAT?
yes and no, because i prefer Unifi's interface, so used the security on it and its semi IPS , thus it indirectly became D.Nat which i prefer as indirect security "feature " lol
hmm not sure if you have missed the thread by @TanKianW, from https://forums.hardwarezone.com.sg/...wrt-on-gl-inet-routers-for-new-users.6592979/
for my own use case,
initial was FW purple for travel, and security . but the wireless on the purple is so cui that it DC a couple of times whilst travelling back to hanoi.
For the next couple of years, after indept research, landed myself on the axt1800 slate AX [ https://www.gl-inet.com/products/gl-axt1800/ ]
its so much better in that , wireless is bang on,
and with its chip, i can be sure my wifu and the rest gets 2mbps for their youtube streaming, nocap, i was watching 4k in the room whilst she was video calling someone without issues
[ if it was FW purple, sure DC within 2mins]
If the guest wifi is of concern, its certainly more better than dealing with FW purple's piss poor lack of proper support.
for Gl-inet : https://docs.gl-inet.com/router/en/3/tutorials/connect_to_a_hotspot_with_captive_portal/
it has never failed, and with its underlying [ OpenWrt. LuCI ] , advance settings have been played around with SQM and one of the hardened wifi addons, cant recall at the moment .
and Land port just grabs , whatever IP address your hotel has issued to that room Port,
but my experience in hanoi hotel, via LAN port , is to go in deep into the router, if possible and copy the router IP address and your first 10 ip address issued when you reach the hotel.
because of the cheap out inTech for some of the hotels in less developed areas, their main Router pumping the IP for each room, might still hold on to their old ip address
but when it came to FW, if your just basic use is ok , but priority is securite sure.
But if its wireless, Glinet hands down for travel router
but as of now, im just thinking of using the Cloud Gateway Ultra when i travel, and pair with my slate AX, since the amount of online [problems ] are just picking up even more
heck even the Unifi Express might be enough as additional layer of IDS/IPS
More info about GL.iNet from brother @TanKianW. You can either use stock FW or official OpenWRT FW.
GLiNet has different range of product, travel router is one of their strong points (like GL-MT3000 Beryl AX). But they also have models (like GL-MT6000 Flint 2) which is more suitable as a normal home router.
Official OpenWRT support:
https://openwrt.org/toh/hwdata/gl.inet/start
https://openwrt.org/toh/hwdata/gl.inet/gl.inet_gl-mt3000
https://openwrt.org/toh/hwdata/gl.inet/gl.inet_gl-mt6000
++++++++ Reference from OpenWRT forum +++++++++++
Best New Comer Router for OpenWRT 2024
https://forum.openwrt.org/t/best-newcomer-routers-2024/189050
- GL.iNet GL-MT3000 68 - Right around $100, available now, easy installation, plenty of horsepower - Thanks @qunvureze for the recommendation
- Netgear R7800 30 - Older model, well under $100 used, easy to flash, only handles SQM to about 180mbps - Thanks @slh for the recommendation
- GL.iNet GL-MT6000 67 - This appears to be a great router, and is now officially supported with OpenWrt 23.05.3. Its price (~US$159, March 2024) doesn't quite meet the criteria, so you will need to decide if it's worth the extra money. Thanks to many people for the recommendation
I don't think MT3000 and MT6000 has SIM card slot right? For a travel router, other than WAN connectivity via wired, I think a handy function is that it should accept 4G/5G WAN on the road as well.
