Do u all belive in bazi / zi wei dou shu? - Part 13
BJPK888
is 化忌 considered as a form of 落陷?
For example, 当限年疾厄宫见落陷的太阳星时发病 but the 太阳 is not 落陷
BJPK888
So some of the stars have 自化 but also have(四化)in the original chart.
For example, you have both 天机自化忌 and 天机忌, then which takes precedence and how?
:oops::oops:
ZhouXingXing
:oops::oops:
you mean the 本命版天机化忌 and 流年天机 again right? if yes, it mean on that 流年 天机双化忌 and the impact is like double
ZhouXingXing
https://ibb.co/xJ79ZyC
See example. Both appear in original chart so I'm curious if you can have both?
Example is 自化绿 and 化权 but same question
can.. but your original chart mean 本命盘?if yes, only type type of 4化 (red color) will appear like one 权,科,禄,忌。you wont see 2 权 etc..
if you go into 流年 or 大限盘, you can see blue and green. The 本命,流年, 大限 4化 will appear on the chart and they can stack on each other like below pic
BJPK888
No leh. U see attached for a random chart I generated. It has both in the children and spouse palaces thus my question. I used 本命 setting
ZhouXingXing
from the pic u attached, it shows 大限 化权。it mean you have clicked on one of the 大限 tab.
if you only look at 本命盘 alone without 流年 or 大限, it will not show any 流年 or 大限 4化 at all.
