Divination lot from Guan Ying Temple at Bugis - Part 2
luckygal
Let say I ask a qns - Should I go to this place? Yes or No
If answer is no of course I will not go liao. If answer is yes I can go but after some thought, I decide not to go. Is that ok?
Pearce
actually it wont count as long it hit anything to be accurate and you can tell gym that will re throw due as the bei hit something..
Pardon me, how did you derive "wont count as long it hit anything to be accurate"?
From books? From the people work in the temple?
Sometime when people throw, they did not deliberately want to hit something as when they throw it on the floor, it bounce to somewhere else.
For example, you flip coin to decide an outcoming by doing 1 try. However, when you miss to catch it on your hand and it hit on the floor, roll until hit a wall and finally it stop, that's the answer for you. Will you count it as not accurate?
ZhouXingXing
This theory is from taiwan master, wont find online or people from the temple (some would know)
for the benefits of people here, the reason why your bei hit something and it wont be counted is because when it hit something and resulted in sheng bei, it can be subjected to scrutiny or challenge like results of the throw are affected or influenced by the surrounding like hitting table or feet of someone etc..
however, there are people who think its acceptable but again, its up to them.
webdeveloper
You mean using using 3 sheng beis for yes answer and you gotten either 1 sheng bei out of 3 throw or 2 sheng beis out of 3 throw ?
yes correct. Does 1 sheng bei out of 3 and 2 sheng bei out of 3 have different meaning or they are all the same as just a no and no special meaning?
ZhouXingXing
for 1 sheng bei out of 3 throw = no answer..
usually if first throw is sheng bei and 2nd throw is not = no answer already, no need to throw the 3rd time..
as for 2 sheng bei out of 3, it still mean a no as it did not fulfill 3 straight sheng beis..
as for more advanced usage of sheng bei, if the person can get first 2 throw is sheng bei and the last is not, it mean 70% yes.. so the person have to identify whats the 30% inorder to get the complete 3 sheng beis.. if the person is unable to identify the 30% and just take it as yes answer, the outcome usually will be opposite..
mgx-alander
人间苦海,求神佛祈福
苍生求一丝希望,但一切都归天命
天命不可为,以福报做数
:sad:
webdeveloper
yea i am wondering about this... like is first i sheng bei mean 33.33% and second is sheng bei is 66.66%.. i am wondering about this but dont know if got this meaning or not that all... just want to double check. For example of houses cases, if you ask first house get 2 sheng bei, second house 1 sheng bei and third house 2 sheng bei... what does it meant? mean first and third house is can take but need to look out for something or actually all 3 cannot take and the 1 or 2 sheng bei has no meaning.
ZhouXingXing
I asked GYM if i will have the opportunity to join back my previous company which I just left 4 months ago and GYM give me lot 10. Can anyone help interpret?
This lot say not easy to go back again, if got someone tell you can, cannot 100% believe..
ZhouXingXing
Nope it does not work like that.
if got back 3 sheng bei = yes,
if no have = all cannot take.
First house maybe can take but got some thing need take note and you need to find out whats the issue on the spot and re ask the question for first house again, if you get it right, you will get 3 straight sheng beis.
For example, you got 2 sheng beis (first 2 throw = sheng bei then count) for house A and you managed to identify the issues and rephrase your question into House A suitable to buy but have to take note of the neighbours around that unit, if this is the case give you 3 straight sheng bei...
If you got it right, you will straight away get 3 sheng beis. if not, you wont get any sheng bei...
Lets say you just proceed on to buy house A just based on 2 sheng beis and the last 30% is really to take note of neighbour which you cant identify.. in near future when you moved in, you will face issues with the neighbours and like machiam bought a not good house.. To use this method, really need tap on to alot on experiences, if not very hard and get confused along the way..
So the most easy one is to use 3 sheng bei as yes, if no = not suitable..
webdeveloper
Then for 1 sheng bei mean forget about it because there are too many rephrase needed?
ZhouXingXing
if only get one sheng bei like first throw is sheng bei and 2nd throw is not, mean ans is no.
its not because of too many rephrase too and for 2 sheng beis, its also not about rephrase, its about knowing the one factor then can have yes answer.. example is the company good for me, if its good will get 3 straight sheng bei but when there is only 2 sheng beis (first 2 throw), it mean the company is considered to be good for you but………
so when you managed to know what is the but then you will get 3 sheng beis.
ZhouXingXing
i see. i also asked GYM if i will have the opportunity to find my dream job in the next 2 months.. GYM give me lot 83. May I know what does it mean?
this lot only say you got high chance finding one after mid of the month but never say which month..
could be after mid of next month or after mid of few months down the road…
webdeveloper
Ok got it. Because I am thinking if having 1 or 2 sheng bei is it the same as first throw already no sheng bei.
BJPK888
I remember the area at waterloo temple for people to throw their sheng bei are very tightly packed. Once saw someone kicking another person's qian away.
webdeveloper
I remember the area for people to throw their sheng bei are very tightly packed. Once saw someone kicking another person's qian away.
Yea I kenna this before which I think is very inconsiderate... For me I will always walk behind the last row and cut into the column with empty kneel cushion
