Vivo X100 series
boringLife-
Anyone AI function is very poor? Keep on kena network error
Vivo photo app on origin OS has ability to AI erase objects but keep on kena "network error" when I am playing around with it
leoklunity
The Ai erase work for me. It may have error but if you can make it identify the object, try a few time, it worked. And its quite good
Took me at least 2 or 3 try but it will worked. I am surprised of the result
DaClovers
I am on china rom. Recently i having delayed notification. I need to manually launch the app to allow the telegram msg or WA msg to come in. Any way to fix it? Also my Gboard sometimes doesnt show what i actually type when i switch to another app from a full screen game
animeonegai
Auto start turn on? If so play with permission and notification settings.
eddy0505
hi senpais, those who are using vivo x100/x100 pro as main driver (not spare phone to just game, wifi without sim card etc)- can check the following:
1. hows the desktop mode when connecting usb c hdmi out to external portable screen? good or just as good as mirroring at best?
2. hows the heat in normal usage/gaming/extensive multitasking? i've bad experience with MTK phones heating up thus main concern.
3. hows the battery with full data and/or wifi
thanks!
eddy0505
Yes. It's on. I reinstalled and it works. But then after 1 or 2 days the same thing happen again
check if app is under battery saver mode - shud be the same for all china roms. if yes, turn it off. I read that originos has resolved all notification issues, seems like there is still aggressive optimization on apps.
shager
Eh, their retail shop close doesn't mean they exit SG ah,
u can still buy from their Shopee store or like what most ppl here do, buy from malaysia
But their Shopee and Lazada store until now there is still no x100Pro.... but if buy from Malaysia, need to service in Malaysia.
dilphinus
do you really think you'll need to service the Vivo phone?
you think way too much? I never had to service any of my phones except for Asus which was a real piece of sh!t.
I have had Samsung, Redmi, Xiaomi, Sharp, Motorola, SE, Nokia, iPhone, Huawei and now Vivo. Never had to service any of these phones.
If there's a need to service your Vivo phone, it will probably cost lesser to do it at the ah beng ah seng mobile stores in Singapore.
