USB Wifi Adapter
hwzlite
I am getting from Taobao Fenvi flagship store the following two items.
1) Fenvi Intel BE200 laptop WiFi 7 adpater (RMB141)
https://www.fenvi.com/product_detail_50.html
2) Fenvi WiFi 6E AXE5400 USB adapter with USB extension (RMB118), not so sure how good it is.
https://www.fenvi.com/product_detail_47.html
I will carry out the test once they are arrived, probably in three to four weeks (Taobao 3rd party sea shipping). I will most likely test the USB adapter first.
alex22
I bypassed the whole cnvio and cnvio2 subject and opted for m2 qualcomm 6e at SGD$12 instead.
Older equipment, Gen 9 intel chipset.
Taobao, 1 week, air included in price.
For usb adapter, comfast 972ax.
Shopee have. $29.90
Taobao have. Rmb138
Own a couple of comfast units since N300 and they have worked well, some managed to do AP mode support even.
TS, how you determine your wifi card spoil and not just driver issue or hard\software switch control issue?
Srenz209
Shopee have. $29.90
Taobao have. Rmb138
When I tried to select the globe icon on the bottom right, no connection shows up. I tried to uninstall then re-install the driver as well, didn't help.
alex22
Control panel, device manager, networking devices, can see if the wifi device shows up or shows up with a ! or ? on it ma?
alex22
Try remove device thru the device manager, reboot n return there, see if it gets picked up with default picked driver.
In the meantime can buy the usb adapter liao on Shopee lol
Srenz209
Tried your method, also didn't help. Still got the same issue.
zerodddd
I got one from sim lim square.
no brand adaptor, nano size, 633mbps 2.4ghz+5ghz combined
tested with 5ghz connection at home, the actual speed was about 250mbps
Or go for better one that based on WIFI6 (802.11ax) instead, like the Comfast 972AX (Realtek RTL8832cu)
or the 952AX (Mediatek MT7921au) for Bestest linux support.
I actually got myself a FENVI AX1800 (Mediatek MT7921au) from taobao , yet to torture-stress test it :grin:
Fenvi WiFi 6E AXE5400 USB adapter is based on Realtek RTL8832CU.
I find it has compatibility issues with my Asus RT-AX86U (packet loss, Broadcom BCM4908 CPU + BCM43684 5GHz WiFi chipset) but no issues with my ZTE BE7200 Pro+ (ZTE CPU + MediaTek WiFi chipset). Tested with my Acer Windows 11 laptop for multiple times (close range).
1) Packet loss with Asus RT-AX86U router (CH60, DFS, 80MHz channel width)
Bash:
PS C:\work\speedtest\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.45 ms   (jitter: 2.84ms, low: 3.29ms, high: 9.00ms)
    Download:   732.01 Mbps (data used: 735.0 MB)
                 11.31 ms   (jitter: 21.84ms, low: 5.46ms, high: 233.05ms)
      Upload:   598.15 Mbps (data used: 1.0 GB)
                 25.87 ms   (jitter: 8.74ms, low: 3.10ms, high: 64.87ms)
 Packet Loss:     5.1%
  Result URL: https://www.speedtest.net/result/c/68e66e1c-35e7-436c-983b-2a16b6d15a17
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.80 ms   (jitter: 1.81ms, low: 3.07ms, high: 6.59ms)
    Download:   740.11 Mbps (data used: 619.6 MB)
                 11.27 ms   (jitter: 20.97ms, low: 4.02ms, high: 526.55ms)
      Upload:   593.41 Mbps (data used: 851.3 MB)
                 24.25 ms   (jitter: 8.66ms, low: 6.07ms, high: 50.56ms)
 Packet Loss:     3.1%
  Result URL: https://www.speedtest.net/result/c/a688dabe-eea7-42ba-bf69-8a4851e94a37
2) No packet loss with ZTE BE7200 Pro+
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.34 ms   (jitter: 2.02ms, low: 3.01ms, high: 7.00ms)
    Download:   731.49 Mbps (data used: 1.2 GB)
                 12.46 ms   (jitter: 13.11ms, low: 4.53ms, high: 131.31ms)
      Upload:   484.79 Mbps (data used: 826.0 MB)
                 23.86 ms   (jitter: 13.03ms, low: 5.24ms, high: 245.59ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/3f53eacf-e96d-4f35-bb35-65da31af1e2a
PS C:\work\speedtest\ookla-speedtest-1.2.0-win64> ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.62 ms   (jitter: 0.46ms, low: 3.18ms, high: 4.12ms)
    Download:   738.36 Mbps (data used: 471.6 MB)
                 12.32 ms   (jitter: 2.94ms, low: 6.62ms, high: 24.44ms)
      Upload:   507.03 Mbps (data used: 839.8 MB)
                 25.06 ms   (jitter: 14.57ms, low: 4.43ms, high: 246.31ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/864919ff-bb94-4c4e-a7f3-653a450deae1
@hwzlite
Maybe you want to edit your post, Realtek RTL8832CU (along with RTL8852CU) USB WiFi 6E chipset is not supported by Linux as per the link you mentioned. RTL8832BU and RTL8854BU WiFi 6 chipsets are also not supported. For USB WiFi 6/6E/7, the link only recommends MT925 WiFi 7 and MT7921AU WiFi 6E chipset.
https://github.com/morrownr/USB-WiFi/blob/main/home/USB_WiFi_Chipsets.md
InterfaceStandard
Maximum
Channel
Width​
Linux
In-Kernel
Driver​
AP Mode​
Monitor Mode​
Recommended
For
Linux​
Mediatek MT7925​
USB3WiFi 7
160​
✔️ 6.7+​
Yes [4]​
Realtek RTL8852cu​
USB2WiFi 6E
160​
❌ [6]​
No​
Realtek RTL8832cu​
USB3WiFi 6E
160​
No​
Mediatek MT7921au​
USB3WiFi 6E
80​
✔️ 5.18+​
Yes​
Realtek RTL8852bu​
USBWiFi 6
80​
❌ [6]​
No​
Realtek RTL8832bu​
USB3WiFi 6
80​
No​
Realtek RTL8852au​
USB2WiFi 6
80​
❌ - avoid [2]​
bad driver​
bad driver​
No​
Realtek RTL8832au​
USB3WiFi 6
80​
❌ - avoid​
bad driver​
bad driver​
No​
hwzlite
Sorry for my bad england, I should have proper sentencing to mean "the 952AX (Mediatek MT7921au) for Bestest linux support.".
Realtek is well known for.....
Realtek does not support their modern USB Wifi chipsets with in-kernel drivers (this statement is true even though we saw in-kernel support for some Realtek WiFi 5 chipsets in 2023. The support for USB was not added by Realtek but by a Linux community developer). Realtek does make non-standards compliant Linux drivers for many USB chipsets but does not publicly release them or take problem reports from the public. A very limited number of vendors post Realtek USB WiFi drivers at very irregular intervals. These drivers are released in source code format and must be compiled to be used. The Realtek drivers do not keep up with the needed changes as new kernels are released. This job seems to rest with folks like myself in the community. Am I a fan of how the Realtek USB team supports the Linux community? No. What do I recommend? Buy adapters based on chipsets from the company that is doing it right - Mediatek
Looks like Fenvi WiFi 6E AXE5400 USB adapter (based on Realtek RTL8832CU chipset) also increases latency judging from the Waveform.com bufferbloat test results compared to my Intel AX201 WiFi 6 adpater.
1) Fenvi WiFi 6E AXE5400 USB adpater with Asus RT-AX86U router -- C
https://www.waveform.com/tools/bufferbloat?test-id=e1f36312-c6b4-4c49-8471-4352d677b558
2) Fenvi WiFi 6E AXE5400 USB adpater with ZTE BE7200 Pro+ router (Double NAT) -- C
https://www.waveform.com/tools/bufferbloat?test-id=03c6c0b3-c109-4d26-995d-ef4c60dea13b
3) Intel AX201 built-in WiFi 6 adpater with Asus RT-AX86U router -- A
https://www.waveform.com/tools/bufferbloat?test-id=6add5d77-cf4d-4755-a7cd-08cf666ce705
4) Intel AX201 built-in WiFi 6 adpater with ZTE BE7200 Pro+ router (Double NAT) -- B
https://www.waveform.com/tools/bufferbloat?test-id=e84589c2-67c1-4202-a976-06716cec32fe
Conclusions -- not worth buying the Realtek RTL8832CU chipset based WiFi 6E USB adapter.
BTW, I also have the old TP-Link T9UH AC1900 adapter. It has never been able to perform like an AC1900 adapter. Even though the PHY link speed is at 1300Mbps (3x3 AC WiFi 80MHz) but the real WiFi speed is worse than those built-in 2x2 AC 80MHz Adapter (867Mbps PHY speed). It is also based Realtek RTL8814AU USB WiFi 5 chipset.
https://www.tp-link.com/sg/home-networking/adapter/archer-t9uh/
Tested with both my Asus RT-AX86U router and ZTE BE7200 Pro+ router.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     4.57 ms   (jitter: 0.20ms, low: 4.36ms, high: 5.01ms)
    Download:   248.62 Mbps (data used: 121.8 MB)
                 20.80 ms   (jitter: 7.77ms, low: 3.97ms, high: 32.50ms)
      Upload:   243.95 Mbps (data used: 249.2 MB)
                 45.20 ms   (jitter: 7.98ms, low: 7.63ms, high: 112.04ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/b6bf1e1d-5292-4556-bc7e-4531fd97656d
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     4.65 ms   (jitter: 0.25ms, low: 4.18ms, high: 4.78ms)
    Download:   257.35 Mbps (data used: 125.9 MB)
                 17.83 ms   (jitter: 8.29ms, low: 5.08ms, high: 34.59ms)
      Upload:   241.42 Mbps (data used: 219.9 MB)
                 83.72 ms   (jitter: 12.70ms, low: 6.90ms, high: 143.53ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/a6cf93b8-6513-4974-93cc-c9637249a63f
Waveform.com bufferbloat test results:
1) TP-Link T9UH WiFi 5 AC1900 USB adpater with Asus RT-AX86U router -- C
https://www.waveform.com/tools/bufferbloat?test-id=eba156ee-7d0b-4344-9f30-e2ac71199c96
2) TP-Link T9UH WiFi 5 AC1900 USB adpater with ZTE BE7200 Pro+ router (Double NAT) -- F
https://www.waveform.com/tools/bufferbloat?test-id=ebeb3ec6-f4a0-42ed-8a26-695ca9d90ef2
Same issue on a low end Intel N100 Mini PC (Chuwi HeroBox, Intel N100 CPU, 8GB/256GB, below S$200 from Shopee), one wall in between the mini PC and the router.
Bash:
PS C:\work\speedtest\ookla\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.54 ms   (jitter: 0.15ms, low: 2.51ms, high: 2.82ms)
    Download:   635.24 Mbps (data used: 746.1 MB)
                 13.96 ms   (jitter: 28.52ms, low: 4.75ms, high: 548.67ms)
      Upload:   442.38 Mbps (data used: 545.3 MB)
                 34.17 ms   (jitter: 12.97ms, low: 10.65ms, high: 135.41ms)
 Packet Loss:     4.0%
  Result URL: https://www.speedtest.net/result/c/feccb501-bd06-4ceb-8af8-9d2e8830a728
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.33 ms   (jitter: 0.36ms, low: 2.05ms, high: 2.74ms)
    Download:   620.95 Mbps (data used: 677.3 MB)
                 12.88 ms   (jitter: 4.22ms, low: 4.88ms, high: 24.25ms)
      Upload:   426.86 Mbps (data used: 723.1 MB)
                 28.53 ms   (jitter: 11.80ms, low: 8.98ms, high: 67.09ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/ee58dd0b-3285-4365-8fe8-07d23c41fdff
Fenvi got multiple version of AX1800 USB WiFi adapter
One of them is based on Realtek 8832AU -- (without two antennas sticking out), the driver is built-in the adapter (emulated as a CD-ROM by Windows).
No packet loss with my Asus RT-AX86U, tested with Acer Windows 11 laptop, 3m away.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.79 ms   (jitter: 0.61ms, low: 3.37ms, high: 4.54ms)
    Download:   669.36 Mbps (data used: 1.2 GB)
                 12.59 ms   (jitter: 6.82ms, low: 5.09ms, high: 231.74ms)
      Upload:   347.65 Mbps (data used: 454.2 MB)
                 45.20 ms   (jitter: 16.86ms, low: 8.90ms, high: 190.97ms)
 Packet Loss:     0.4%
  Result URL: https://www.speedtest.net/result/c/00bf1ae2-7dc9-404d-9863-40031addc8ef
No packet loss with ZTE BE7200 Pro+ either, tested with Acer Windows 11 laptop, 4m away.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.92 ms   (jitter: 0.05ms, low: 3.87ms, high: 3.98ms)
    Download:   526.75 Mbps (data used: 940.6 MB)
                 16.68 ms   (jitter: 6.65ms, low: 4.59ms, high: 40.04ms)
      Upload:   293.48 Mbps (data used: 262.4 MB)
                 40.59 ms   (jitter: 18.61ms, low: 9.47ms, high: 205.56ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/5d16244d-a55a-49a5-94a1-5ee42185a1f4
The other Fenvi AX1800 WiFi adapter is based on MT7921AU.
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.17 ms   (jitter: 0.17ms, low: 3.15ms, high: 3.49ms)
    Download:   574.77 Mbps (data used: 637.7 MB)
                 12.51 ms   (jitter: 7.96ms, low: 5.03ms, high: 238.19ms)
      Upload:   455.66 Mbps (data used: 606.6 MB)
                 17.77 ms   (jitter: 29.64ms, low: 4.00ms, high: 255.07ms)
 Packet Loss:     0.6%
  Result URL: https://www.speedtest.net/result/c/85edd181-c9e1-464f-b20a-23062c081d46
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     4.09 ms   (jitter: 0.65ms, low: 2.94ms, high: 4.66ms)
    Download:   660.51 Mbps (data used: 686.9 MB)
                 11.67 ms   (jitter: 7.86ms, low: 4.11ms, high: 231.63ms)
      Upload:   447.93 Mbps (data used: 728.4 MB)
                 28.26 ms   (jitter: 39.94ms, low: 2.71ms, high: 1920.38ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/41ae6088-7d16-457c-b98d-5d6b10d063c8
