Guys, when u all midnight wake up to pee or morning wake up to pee with harden kkj.. do u sit to pee to avoid spraying all over the bowls?
Mr Anonymous
Not so often prostrate but adhesions in the urethra. If you feel brave and have the flexibility to do so, spread the glans look at the tube inside. You might find a membrane splitting the tube into two. Usually caused by old injury. I think I got mine when I took a kick to the dick during a MA class.
Hmm now that u said this.. Last time i primary sch time, go see saw play and i fell hard n hit my kkj & balls... Almost knocked out.
is it will result in always splitting? I sometimes only will experience split streams.
DragonFire
It happens when the lining is torn and the two torn edges partially stick.
joogii
Can't try half squat?
Low enough to aim properly and not splash wrong place?
spinning_quirK
Those who wash toilet themselves will known that pee lingers in the drain. The stench lol.
If squat and aim the pee into the drainage hole, with minimal splashing on surrounding wall and floor tiles, then rinse with water for 10 seconds, no smell de
pmetpmet
Chop liao will have no such problem :ROFLMAO: :ROFLMAO: :ROFLMAO:
12inch to 3 inch, still can press into the bowl :ROFLMAO: :ROFLMAO: :ROFLMAO:
