Unlock code needed for F35 fighter jet
virtualape
Safety feature. If they can generate the code, they can connect to the plane instruments. Ie can remotely control it. No need pilots
Chalkycliffs
use coin operated maybe better. fly 5 mins $2?
Really Uncle Sam's lapdog...
MiG123
Wumao will use AI generated videos with <10views to support their claims as long as it fulfils their narrative
AZE
If they can remotely control drones with base station/sats, there ish no reason they could not do it to F35.:o
All along already got ppl said that F35 ish "region locked" ones...
Maybe take off 1/2 way switch off engine then tio forced to eject, or fly 1/2 way then flight system disabled then jet ownself nose dive...:o
That Mah across the causeway also mentioned before, he all along don't rike USA planes, because usage need "permission", sho no permission ish at most allowed to fly during national day...
AZE
ASML is able to disable their lithography system in Taiwan, rendering them unusable, if China invade.
Tear apart and China ownself ish can reverse engineer loh...:o
Heard the real plan was that US will find some excuse or send black hands to blow up all the important fabs...:o
SecretAgent
Disabling remotely is not a new thing for any tech which is connected.
They don't have to go to that extent...
Disabling Link16 data link can very effectively neuter it..
Timber_Wolf
NOfLine
All F-35 users are 'slave' to the codes. All you need is one bug...awaiting an input to activate.
That is why F-16 and F-15 production lines still going strong.
tank_t
I believe the weapon & targeting system could recognise US asset and fail to lock.
Planes are just planes.
kreja
If i got skills, ill make a video showing F35 transform into starscream and i bet you will share in edmw thinking its true....
Use some critical thinking, if this kind of info can share on youtube, FBI, CIA, USA intelligence community jlb?
