- Sep 16, 2018
Just tried the above FQ_CODEL limiters under pfSense CE 2.7.2 (Double NAT behind Asus RT-AX86U), the limiter works but I do not see changes in terms of download/upload latency of wired clients.
Unfortunately Singel has no good connection to Waveform.com bufferbloat test servers, I can not use that one to get meaningful test results.
Therefore I have to use OOkla SpeedTest. I can not see the differences in the following test results using wired client. In fact, it is slightly worse with the bandwidth limiters (900Mbps down, 700Mbps up).
I believe the limters can be useful for some use cases. My results may be related to the fact this is one test installation with Double NAT.
Without traffic shaper:
With traffic shaper:
Bash:
root@ubuntu2204ct21:~# ./speedtest
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 2.29 ms (jitter: 0.08ms, low: 2.22ms, high: 2.45ms)
Download: 916.38 Mbps (data used: 425.0 MB)
3.11 ms (jitter: 0.68ms, low: 1.25ms, high: 6.49ms)
Upload: 938.88 Mbps (data used: 1.1 GB)
5.98 ms (jitter: 0.62ms, low: 4.55ms, high: 15.53ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/c7e5d3eb-2b19-450f-a445-bf8941f2b39d
Bash:
root@ubuntu2204ct21:~# ./speedtest -s 13623
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 2.37 ms (jitter: 0.15ms, low: 2.17ms, high: 2.58ms)
Download: 850.66 Mbps (data used: 385.1 MB)
3.00 ms (jitter: 6.41ms, low: 1.58ms, high: 208.16ms)
Upload: 681.82 Mbps (data used: 781.0 MB)
7.66 ms (jitter: 0.85ms, low: 3.35ms, high: 15.09ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/47ae8267-f1f7-4a3e-8e4f-449c1bd0ce17
