- Sep 16, 2018
Hi guys.
I am on Whizzcomms. Which dns should I use to have best performance and high level of security?
It all depends on your needs. Usually a router will give you options to list at least two DNS servers.
Personally I use Quad 9 and Cloudflare 1.1.1.2 (malware blocking only) or 1.1.1.3 (malware and adult contents blocking, good to use if got kids).
WC does not seem to have IPv6 so you will not encounter the high latency issues I have with SingTel IPv6.
Take note just using these type of public DNS with filtering will not give you high level of security. Most important thing is to be careful and learn the ABCs of cyber security. For example, do not anyhow click a link. That is a very simple rule but many people still do not understand and just click.
CSA Singapore gives some good and simple advice to the general public.
https://www.csa.gov.sg/information-for/general-public
