Can install Aircon for old resale flats once renovations are done?
what's the logic if cannot?Can install Aircon for old resale flats once renovations are done?
old resale flat cannot be new resale flat . Ac canCan install Aircon for old resale flats once renovations are done?
Where to mount the compressor?what's the logic if cannot?
Is only for the living room, other rooms have liao...
Install condensor in the kitchen. Use the hot air to dry clothes.install bracket outside la. u first time in sg?
Yes, but should have checked before doing reno, old resale got no 15-20 amps power supply, need to get permit to run one to your compressor.Can install Aircon for old resale flats once renovations are done?
Yes!!! Mine is facing the laundry, it helps so much even on those very wet weather as we run the aircon throughout most part of the day and night.Install condensor in the kitchen. Use the hot air to dry clothes.
Why cannot my old resale gt original i add on 1 more compressor alsoCan install Aircon for old resale flats once renovations are done?
usually install outside, next to mb toilet for condensed water to flow toWhere to mount the compressor?
the older flats in the past all install their compressors in their service yard...You can do that?
