Anyone have recommended place to print birthday card?
coolhead
Need the shop to have good A4 size paper to print a customized birthday greeting card.
Probably got to send to the shop the Word/PPT by email.
Any recommendations?
coolhead
go sunshine plaza, the paper can choose artcard higher gsm one
but your design must be ready and also good for the size, save on USB and bring there
still got people use USB ah? Thanks for the tip! Lub you dip dip!
Encouragesome1
Think go photo develop shop or those print shop can ask
When I was young bras brasah printers for label artwork many can do
kittyklysm
Suspended
That area used to have of print shops, but the remnants should still be at sunshine plaza. If you want to DIY can buy photo paper and print at home.
Suggest u test print first beforehand.
s-ghost
High Honorary Member
if not how to transfer file
anyway suggest it you got normal printer, do a test print of your file first to make sure alightment and scale works well before going shop
save as PDF as well to make sure image don't run in case of software versioning issues, also have the file on email or cloud as well just in case thumbdrive fails
if i not wrong, A4 artcard is around $2-3 per piece
ah gui used to go Xerox Press but you can check around
