standarture
- Feb 28, 2009
Get a stand DC fan, far better than lousy ceiling fan.
Exactly… I don’t know why sinkies wanna save this kind of money.hire an electrican
Got someone complain sinkies dunno DIY leh. LOLExactly… I don’t know why sinkies wanna save this kind of money.![]()
Low ses 2 room flat no space... wall fans already installed 2.Get a stand DC fan, far better than lousy ceiling fan.
Prefer to do things by the norm...How about drilling the hole slant outwards?
Which is why I prefer expansion bolts rather than plastic plugs... Was considering 3 bolts but I am sibei humji person. leaning toward securing 4th with metal base plate.my ceiling fan 2 anchor bolts nia onto concrete.
i protested and my electrician hang himself onto the plate to demo its more than enough.
he install ceiling fans maciam like hot knife thro butter for years.![]()
Thought of that but only the inner circle of the base plate is flush with ceiling surface...
This one you ask HDB...How come the ceilings hole so wide?
You see for yourself...I can see you got not much to extend but a few mm so total spacing is 100mm is possible
Read HWZ Forum Rules!
Dude I know how to do also... and like you can see from another poster... technican just bolt 2 holes for him nia... practically the offcenter installation I mentioned I would say... In fact, the ceiling fan light came with only 2 expansion bolts... I just more humji than everyone else... I looking for safer more rigid solution. My whole house lights, wall fans are all self installed one. Even the kitchen sink and electrical hob I ownself install.Just engage the technician yo instal the fan for you.
They know how to do.
The hole inner is the concrete wall, that hole is just a false ceiling right?Dude I know how to do also... and like you can see from another poster... technican just bolt 2 holes for him nia... practically the offcenter installation I mentioned I would say... In fact, the ceiling fan light came with only 2 expansion bolts... I just more humji than everyone else... I looking for safer more rigid solution. My whole house lights, wall fans are all self installed one. Even the kitchen sink and electrical hob I ownself install.
No lah newer BTO the light points are all hidden. The light wirings are hidden in the concrete and the hole is the outlet for you to install lights. Solid concrete... so damned hard until my impact drill with general purpose drill bit cannot punch thru after 20mins. Had to buy a hammer drill with concrete drill bit....The hole inner is the concrete wall, that hole is just a false ceiling right?
