2_sillies_trap
- Jul 2, 2023
Scare ban so neh quotes in full. But curious, youyongqun is youyongku sister?W**** ****** **** ***e?
If doctor told me dnt need do I will happy but mine was told me need do surgery.The doctor didnt ask me to do surgery. I was discharged at age of 28. He said it will not grow bigger or smaller already.
Yes, the echo test can pick up valve issues.It can run in family. And condition could progress to a more severe one over time. Once a while U need to have a regular echo check for Ur heart.
wah sounds scary sia need stop heart and use machine. later suay suay power outage or whatever then ggOur heart got 4 valve.There is another valve is high risk operation.
The common heart valve leak call mitral valve prolapse and high operation success rate and other type valve more complicated operation.
I did do research for heart valve operation,you need stop the heart and do repair and put in the machine and let blood flow to other bodyYou need stay in ICU for 2 days.
Yes, my late sibling had severe Afib, didn't go for surgery despite doctor's advice. She was afraid of the pain and mortality risk. Look, any surgery will have risks. If the doctor said the risk is 1-2%, it is quite a good outcome.Had my open heart surgery for mitral valve replacement a month ago. Recovering now. Doc said I have 1 year to get it replaced before risk of failure is too high.
Had the valve repaired 11 years ago but because of viral infection and endocarditis in Nov last year, repair was totally damaged.
Listen to the docs advise. If you need to go for surgery, get it done quickly. We have the best surgeons here.
Did he mean four vessels damaged and not four bypass surgeries?Wah 4 cabg? Wat did your mom do until like that?
Aiyoh they have power back up lah.wah sounds scary sia need stop heart and use machine. later suay suay power outage or whatever then gg
Is this a hypothetical scenario? A competent cardiologist would have given you the right advice. If unsure, seek a second opinion.If have symptoms then consult cardiologist+ CT scan but everything looks healthy, cardiologist say all ok but end up misdiagnosis and up lorry how?
Means what?
I was told to do 5 yrs ago but choose not do.Yes, my late sibling had severe Afib, didn't go for surgery despite doctor's advice. She was afraid of the pain and mortality risk. Look, any surgery will have risks. If the doctor said the risk is 1-2%, it is quite a good outcome.
She passed away suddenly last year. Afib can cause strokes. Heard from her kiddos she had wanted to go for surgery this year. Too late.
Wah..take care bro.If doctor told me dnt need do I will happy but mine was told me need do surgery.
Some valve issues are due to an underlying condition such as an autoimmune disease. Others can be due to a viral infection or aging.Erm doesn't work that way, a valve cannot close properly hence the blood backflow. Not like a hole in the wall or something.
Wah..take care bro.
I also recently goes to polyclinc get a referral letter to national heath centre as having chest pain. Initial appointment is Augst, suddenly changed it to Nov...KNN..i think i better go do cardiac screening myself first
Yes, rapid heartbeat even at rest, dizziness, consistent jaw pain that is not due to dental issues, pain radiating from arm can be warning signs of heart issues. I come from a family with cardiovascular disease.If u have symptoms like shortness of breath easily, chest pain or tightness, even fainting at times, best to go see a cardiologist to run the full set of tests.
Since u decide to opt out of operation, do u need to abstain from rigourous activities? Diet?I discovered 5 yrs ago but dare not go and they told me I am still young not like in 60s so my heart valve can repair if come worse need use animal valve or mechanical valve replacement.
Are the operation tough
Heard need take out heart do repair and stay 1 week in hospital after surgery![]()
Afib can be mild or severe. However, ventrical fibrillation is even more severe. Fibrillation happens when the chambers of the heart do not beat in sync, basically the rhythm goes haywire and blood pools, leading to clots and stroke.I was told to do 5 yrs ago but choose not do.
Actually depend which heart valve leak and some heart valve issue cannot delay
https://www.texasheart.org/heart-he...ch-is-worse-a-leaking-aortic-or-mitral-valve/
Side note: so finally my youngest sibling went for an angiogram as all the older ones have had heart bypass. This sibling eats fried food EVERY DAY and drinks bubble tea EVERY DAY. Guess what? No blockage and no hardening of arteries. Calcium score zero.
I am really speechless. But of course there is still the possibility of blockage at the neck and brain, which she didn't check.
But I am like...is there a reason a higher being is protecting her?
