Amuroraysg
- Oct 27, 2001
GPay works? bus mrt etc?Amazing battery life and no issue with china rom.
Yes all work but not sure on Android autoGPay works? bus mrt etc?
Not sure since I don't use aodWhat about AOD? heard they are limited to showing notification from limited apps only
Forgotis the case included in the phone 1 sided? front dont have?
congratsGot my vivo x fold 3 pro from Indonesia. Overall its better than my z fold 6 not just specs wise. But cant compare funtouch OS with samsung UI. Global set comes with a piece of back casing ( no hinge protection tho). Battery life.. Can compete with my magic 6 pro 5600mAh. So far I've used the china Rom and this global Rom. I must say... Its much better in every way.
can share (if need, via private message) how you get from Indonesia?Got my vivo x fold 3 pro from Indonesia. Overall its better than my z fold 6 not just specs wise. But cant compare funtouch OS with samsung UI. Global set comes with a piece of back casing ( no hinge protection tho). Battery life.. Can compete with my magic 6 pro 5600mAh. So far I've used the china Rom and this global Rom. I must say... Its much better in every way.
How much in sgdOh I got it straight from their vivo store. Walk in and buy.
i check tokopedia selling around 25 million to 26 million... aboutr 2K sgdHow much in sgd
Prefer it on global.Which is better? China ROM or Global?
can set 5 icon in a row for outer and inner screen?Prefer it on global.
What are the factors that influenced your choice?Prefer it on global.
To be honest, I think if something happens and the need to repair etc , I can just go Indo and get it fixed. But based on china and global Rom, bloatware is not so prominent on the global set. I think it's really up to the individual.What are the factors that influenced your choice?
