Hi @Parka, I’ve uninstalled McAfee. When I checked Windows Security, the only section with an issue is “Virus & threat protection” where it says to set up OneDrive (for ransomware protection).You can search for "windows security" in Windows Settings. That will show all the security options available.
Then you just go through one by one to check. It's quite straightforward.
I’m not inclined to set up OneDrive because I do not wish to pay for the service. Can I safely ignore the “warning”?
Thanks.
