Apple Airpods 4
jq75
Guys not sure should I return this. My left ear can’t wear it for some period. it would get loose and might drop. However my right ear can fit and worn longer.
different pple diff ear design
not sure if ap 4 silicone cover avaliable or not for a better fit
jq75
AirPods 4 has no rubber at all
earlier someone method some sensitive to pro silicone tips, so I suggest foam tips.
for pods 3/4, not sure they have silicone cover to give a better fit for those feeling loose pods 4, my earlier pic was for gen 1 pod
anthonygreenisreal
you should just return it. it is very expensive, no point suffering for it
Op_Valkyrie
Sound better or?
Comfort and convenience, my AirPods Pro 2 still need to buy comply tips for comfort and need to buy every few months cos it’s consumable. Sound quality comparable but AirPods 4 with Anc without in-ear bud is more convenient in my opinion.
i.Singaporean
does the 4 cancel alot less noise compared to the Pro 2 because it doesn't have the rubber seal?
Rubick
Never try spinfit ah?
Hearsay the eletech baroque also better
