paul mitchell tea tree shampooAny shampoo or cleanser to recommend
Having trouble washing off wax residue
Indians Dry Shaper was amazing, why has it been discontinued? I haven't found a substitute yet after months for searching. Please bring it back bro!You've described it very well that there are far too many options in the market. What works for others, may not work that well for us. But to share my thoughts too, you may like to consider the below products as possible options.
1. Indians Molding Clay (Dry-clay): Comes w matte finish, strong hold and lightweight
2. Indians Dry Shaper (Soft-clay): Comes w matte finish, medium hold and lightweight
For thick hair, both options are possible for you. The advantage of having thick hair is that you will be able to hold styles well, but assumption is that you did not let it succumb to the high weight of the hair first. To combat against the weight of your hair, the best bet is to complement it with a pre-styler (there's no magic here either). Based on your style, I would think option #2 is something that is more suited for you.
Option #1 goes well with any pre-styler (i.e. seasalt spray, hair powder etc).
Option #2 goes best with hair mousse (particularly Screen Wakin hair mousse, as part of my trial for finding best combination).
Below picture is just for better illustration, where I used dry shaper.
if willing to risk, just shave. Looking nice is impt to self esteem tooWat or how shud i style with this type of hair? N how long shud i keep it b4 next cut? Thanks
https://postimg.cc/V0nkyvnc
But cannot leh. Wife n ma say later head look too oval which i agree especially wen G.I. styleif willing to risk, just shave. Looking nice is impt to self esteem too
https://www.todayonline.com/world/m...ting-hair-transplants-restore-their-locks-and
wife ok is ok le. got maro shampooBut cannot leh. Wife n ma say later head look too oval which i agree especially wen G.I. style
Any recommendations for shampoo that helps with dry and frizzy hair?
Get organic antifrizz shampoo
Sls free
Any alternative to Morris Motley? I tried Blumaan cavalier and Hans de fuko claymation, both is slightly oily for me and difficult to wash off. Still prefer MM matte feel but too pricey liao.
wash your hair then use conditioner. towel dry and then use leave in conditioner and hair oil for hair ends.Any guys here with long hair? Chin length and beyond. What's your haircare regime?
