iPhone 16e/Plus/Pro/ProMax Discussions [No WTB/WTS/Flip]
What color are you buying?
  • iPhone 16/16 Plus (White)
  • iPhone 16/16 Plus (Green)
  • iPhone 16/16 Plus (Pink)
  • iPhone 16/16 Plus (Blue)
  • iPhone 16 Pro/16 Pro Max (Black)
  • iPhone 16 Pro/16 Pro Max (White)
  • iPhone 16 Pro/16 Pro Max (Natural)
  • iPhone 16 Pro/16 Pro Max (Gold)
Jirachi
This 18.0.1 is worse update ever
Keyboard and typing is lag, phone heats up fast and battery drop every 1% less than 2 mins on wifi and minor usage (ig)
Not facing the problems you faced, to be honest.
kashix
At this point in time, I think you just do a clean restore better, setup as new iPhone. Likely will solve all your problem.
cloudystar
huh? y i use aod no sleep mode battery drain only 2%
but battery life other than tt no really big as i expected comin from android
battery with normal use still can only last 1day ++ tt means if go overseas need to charge everynight
Are you on Pro Max? My previous 14 Pro and 15 Pro battery not that strong hahaha 🤣
2% battery drain with aod on overnight is like a dream for 15 Pro users. But I think 16 Pro got improve abit 😃
Op_Valkyrie
No la, got some more knowledgeable users here. Just share findings.
Don't keep attack me today leh ... I meant you no harm ... :(
Bo lah… don mean to ‘attack’ u in any manner. Paiseh if u think this way…. Have a good weekend ahead 🥲
evilduxy
yah 16pro max just got it last tue only lol
past few days i leave it with aod n overnight drain only 2-3%
cloudystar
Pro Max battery life significantly stronger than the Pros although that gap seems to have narrowed with the 16 Pro.
I was weighing the pros and cons between the Pro Max and Pro after using both but ultimately even the superior battery life couldn’t convince myself to keep the Pro Max as it is just too big for my preference.
I think 14 Pro battery was by far the worst with small battery and new features like Dynamic Island and AOD to blame.. 😅😅
symbiote28
anyone's alarm doesn't play the actual music you selected? it just keeps playing the default tone.
kashix
You kept the 16 Pro and is happy with it?
cloudystar
yeah, coming from the 15 Pro really nothing to nitpick on already.
The 16 Pro have bigger screen and better battery life albeit not significantly better. Battery life can last a full day without issues which is most important.
Despite the minimal upgrade, still more than happy with it 😃😃
sallybee
Hi Apple seniors, im coming over from andriod . im keen in the 16 series but im not a pro user. i DONT game, DONT tiktok, DONT edit videos. just simple whatsapp, sms , call, youtube ,facebook and surf web.
is 16 PLUS more worth the money to get or should i invest in the 16 Pro (not pro max)?
please advice
Rubick
please advice
See whether you need the bigger screen and battery life or a faster refresh rate screen and better camera.
garychengjw
please advice
why bother with changing to iphone when you don't do this do that.
why change if it's not "broken" :s22:
ragnarok95
Senior Moderator
Senior Moderator
please advice
Not worth. You can get a pixel that cost less and does the same thing.
iosnewbie
please advice
I suggest you bring your current android phone go to a retail shop with sample IP6 plus and pro models, then take pics with all the phones for the same scenes and compare.
The ultra wide lens on the 16 Pro has comments on reddit as being the worst of all IPhone models.
You should see if the ultra wide lens macro shots are something you can live with.
