BBCWatcher
- Jun 15, 2010
A bridged ONR and ONT function the same way for these purposes.I see so its more likely that they configured the ONR in bridge rather than actually giving me an ONT.
Or don't. If for example you've got a wired device located near the ONR then you could plug that into the second (or third) port, and it'll get its own 1.0 Gb/s that could potentially drive total utilization across the fibre above 1.0 Gb/s. Which still might not matter, but if it makes you feel better...humm i'll need to pull another cable if wan port aggregation is needed as the router is a couple metres away from the DB box. but that means its still max 2Gbps. they are really misrepresenting their product imo![]()
Darn.1. FYI, WAN Aggregation does not work since none of local ISP's ONT/ONR support LACP-IEEE 802.3ad.
Yeah, not really worth it.2. What will work is Dual WAN Load Balancing. But then the Asus router needs to be configured in router mode and you have to live with Double NAT, which may or may not cause issues depending on the use cases.
https://www.asus.com/sg/support/faq/1050116/
