🛞 My honest review of Hankook Ventus Prime 4
Elfblade
I think it started out as regional tyre brand.
U go wiki see
Originally from Putian, Fujian Province in China. Now headquartered in Singapore for better branding I guess.
Ambergris
Tried it out on 205/55R16
Grip wise, feels like similar grip level as previous Tyres.
Quite good on dry, quick lane switch wun feel the Tyre wall lembeh over. Dry brake is good.
Haven't test wet perf much yet.
Noise, is abit similar to previous Tyre, maybe just slightly noiser.
Comfort wise, is on the comfy side.
FC wise, slightly worse than previous Tyre.
Good replacement for economic call I feel from price per overall offering perspective
Those who want a comfy n quiet ride, can consider this Tyre :o
What was your previous tyre?
Shutterbox
Guy from putian, but I think he started out tyre making in indonesia?
At least that's what wiki says
menthol28
R16? Nowadays I think minimum come R17-18 liao
But I much prefer 16 inch, cheaper tyres and dun need heartpain
Elfblade
16" also slightly more fuel efficient, but I am used to 17" RIMS, tried 16" b4 and the car and I don't like the road feedback and handling. After a couple of months I switched back to 215/45/R17, the sweet spot.
Asphodeli
how much for 1 tyre? :o
tk
Me just changed to ventus prime 4 205/55R16 at a good price of $360.. :cool:
kelvinti
Tyre Gurus,
I'm driving a CN7 with 205/55/R16 Yokohama ADVAN dB V552 now, obviously for comfy ride and not so noise ride!
Is it worth to change to this Hankook Ventus Prime 4 in view of the offered is about $385 inclusive of GST, types balancing, new aluminum valve and nitrogen gas (in which I would opt for normal gas instead!)?
Coz I find the V552 is kind of "floating" on dry road! 🤭 :sick:
Shutterbox
Tyre Gurus,
I'm driving a CN7 with 205/55/R16 Yokohama ADVAN dB V552 now, obviously for comfy ride!
Price is not bad la.
If your Yokohama is high mileage liao, can consider la.
Just make sure new taya YOM is 2024 one.
kelvinti
My 2024's v552 is only 3 months old..... 😬 🤭
The offered Hankook is a 2024 one..
I just want opinion if I should "anyhow" / worth the hard earned pocket money to spend that $380+ for this Hankook tyre considering that my current V552 is just 3 months old? :sick:
Shutterbox
If the current taya served u well, save the money la
kelvinti
True also!. V552 is quite a nice tyre even though I feel that my car is "floating" a bit on dry road!
Okay. keep the money for other more useful expenditures then! Thank. 🤗
tk
Tyre Gurus,
After driving on Hankook 9ventus prime 4 for a month.. I'm happy with the grip, control and noise level.. felt just as good as pricier Michelin Energy XM and Bridgestone GR80 that I used last time.. and better than other tires I had from Nexen, Laufenn, Hankook..
Comparable good tires from other brands like Michelin, Bridgestone, Continental, Pirelli would cost more than $450, so I think I made a good choice..
jasvonvios
Davanti dx390, quiet and comfort tyres, 205/60/R16, 4 PCs at $284.77 after all the discount at shoppee.
