Singapore Treasury bills (T-bills)
PhantomOpera
You got factor in the fees?
May I know what fees are involved?
Or you meant the loss in interest for the months in which funds are transferred to and from the OA? For the latter, I used this table as a yardstick:
If u not successful u can refund on the auction date itself
Noted, thanks
reddevil0728
Noted, thanks
You use cpf to put t-bill you never notice got fees involved?
reddevil0728
Oh I didn’t realize. The fees are deducted from where??
The amount deducted from your cpf upfront includes some fees already.
then when u were holding the t-bill you didn’t realise got money taken from your OA?
then at maturity I believe the amount returned also got some fees taken
PhantomOpera
The money taken from CPF OA is not much like $2+ every quarter…didn’t realize got difference in the deduction upfront though
Thanks for the explanation!
sglandscape
I recall only DBS charges fees for maturity (deemed as a sale), whereas OCBC and UOB do not
gregory_choo
I read from Seedly that the breakeven rate for 6m is 2.92% (1 mth lag). So means I shd bid for 2.93%?
The next 6m auction date is 24 Oct and issue date is 29 Oct. Can I still do the refund in time before end Oct? If I am not successful, when will the refund come back to my CPFOA?
Thanks!
since you are using matured cpf t bill to buy again. as long as the yield is higher than cpf oa, you are better off.
the figure from seedly is for fresh fund from cpf , and return to cpf immediately upon maturity. not applicable for you.
PhantomOpera
Thanks much everyone!
maumu
I found that the thing about 1-year bill is that the maturity is after the next 1-year bill so one has to wait like 2 months before rolling over (which technically doesn't look like a rolling over).
my 1-year bill which matured in July is still sitting in SRS until now. two months (Aug and Sep) cannot earn anything (higher than 0.05%) :o
gregory_choo
why wait, go for 6m. usually there is 2 wks break between the old and new.
henrylbh
My T bill (using CPF OA) coming back on 22 Oct. Should I put it back to CPF or reinvest in another 6m T bills? Any advice? Thanks
Whether you going to reinvest in the next T Bill, the logical step is to transfer the matured sum back to CPF about 3 working days before end of the month to earn interest starting next month.
Thanks!
No such issue if you do refund before end of the month as mentioned above.
If not successful, your money transferred back to CPFOA will not be touched.
sdexxxxd
Allotment​
Total Amount AllottedS$6.8 billion
Amount Allotted to Non-Competitive ApplicationsS$1.4 billion
Amount Allotted to MASS$0.0 million
Total Amount AppliedS$14.9 billion
% of Competitive Applications at Cut-off AllottedApproximately 68%
% of Non-Competitive Applications Allotted100%
Bid-to-Cover Ratio2.19
Yield and Price​
Cut-off Yield 3.06% p.a.
Cut-off Price98.474
Median Yield2.9% p.a.
Median Price98.554
Average Yield2.76% p.a.
Average Price98.624
addict951
High Honorary Member
Hokay, nao gear up for the final 1-yr one.
Yall aga will chui till how low ar? 2.5%? :look:
reddevil0728
unfortunately not attractive enough with some banks still giving 3.3%... 3.4% no strings attached (e.g. SC eSaver).
hopefully this will push up next week's 1-year bill rates :)
and is cause no strings attached. hence they can cut anytime and the 6m lock-in of the rate might end up being better off...
Hokay, nao gear up for the final 1-yr one 2 wks from nao.
12m always like lower leh.
