Kyubi
- Jun 2, 2002
Yea.. good price and is new set alsowow did not know that
refurb
AirPods Pro 2 - 289
AirPods 3 with MagSafe charging case - 189
refurb
AirPods Pro 2 - 289
Spoil le give for what?Give to wife, nephew, nieces![]()
Mine is still usable. Just change the earbuds only from M to S size for them.Spoil le give for what?
Yes, or you can book a appointment which is better.Hi guys, if airpods not functioning, can walk in to apple store to repair?
Usually they give u refurbished as replacementHi guys, if airpods not functioning, can walk in to apple store to repair?
If there's no warranty left, how much will that be?Usually they give u refurbished as replacement
Not worthwhile I guessIf there's no warranty left, how much will that be?
1st time using tips? wear it a few times and see if u can adopt to it. i've tried other brands like samsung buds. airpod pros r so far the most comfy for me. not trying to upsell app2, just sharing my experience. u still have time to return the app2.So I tested wearing both earbuds on app2. Default size..
then my right earbud encounter a slap sound pain.. I took out my right earbud and I saw the eartip actually go opposite side .> So I go ahead and push back eartip so it face <. again.
that slap from eartip let my right earbud pain for awhile. Omg.
App2 is older model? It is far superior than ap4. How to compare.Yea i know. I wasted specialist time to santise eartips and put different size for me to wear... I might look to buy memory foam or foam master memory foam. (what different the image on it website below one look like silicion while another one is more foamy).. the foamy one is cheaper..
Memory & Foamy Memory Eartips.
But got to wait as it ship from england. Got to look at shopee xd.
Then i compare my old jbl eartip which is black and look foamy type the size it look alittle bigger than app2 small size. So it probably app2 medium size or small size.
Now i felt app2 default medium size the left more fit than the right one. o.0.
My right felt loose tingling with the fan blowing.
Cant push it deep as it will invert the eartip slapping a ear pain to my right.
Its my first airpod. Felt disappointed as i cant wear Airpods 4 so exchange it for Airpods Pro 2. Lol which is an older model.
is good at least i can wear app2 now. But still thinking of buying memory foam eartip. XdApp2 is older model? It is far superior than ap4. How to compare.
If it's hardware defect yesIs it good to buy apple care for pro 2?
within 2 years can one to one exchange with ac+?
What item? It will automatically be applied to your AirPods serial numberCan just buy AppleCare+ for pro 2 on iPhone 16 setting right? With Apple pay.
they will send the item to hse?
or will activate on spot?
Pro 2What item? It will automatically be applied to your AirPods serial number
