reddevil0728
- Dec 16, 2005
It should renewThe priority card expire on 31st Dec.
If I am travelling on 1st, can I still use the old card info? Or they will auto renew before expiry?
Useless card for me, never have any promotion for so many years, expect to earn base rate forever. I am going to cancel the card once I pay off my BT next month.
u can do more than just redeem miles. can use it to offset other stuffwhat do you mean?
miles per dollar spent never improve?
i find they still give better value vs say Trust Cashback
just that you can only redeem miles
what do you mean?
Hopefully, else I can't use the lounge on the 1st JanIt should renew
Don't worry, you don't have to do anything and it'll auto renew yearly.Hopefully, else I can't use the lounge on the 1st Jan
thank you!anyway, the for premier mile user, the website to register with your invitation code is
https://www.prioritypass.com/citipmvisa I have just called Citibank hotline to check.
apparently, citibank website is not update to the correct web link.
https://milelion.com/2025/12/19/mas...in-singapore-with-the-citi-premiermiles-card/What’s so special about world select card? To me like just a change of name?
thanks..nothing special to me...no extra airport lounge..
you wasted what time?Waste of time carving out another tier. Still prefer the Visa network
Dunno leh. We laypeople without the insights. Only can speculate.not waste my time; I meant why do they need to create this World Select tier with only slight differences
the switch to Mastercard mean higher costs as some merchants process transactions overseas. Agoda Singapore is one of them
The tier allows them to charge merchants higher processing fees.not waste my time; I meant why do they need to create this World Select tier with only slight differences
they say within 14 business days. so they are covered even though lived experience might be fasterAnyone did a transfer of citimiles to Krisflyer recently and it took beyond 2 days.. q strange since my previous transfers were all done within a day or two
