Recommend cheap and good phone less than 200
babywoolf
Hi,
Can anybody recommend any good and cheap android phone that is less than $200? I using it as a second phone.
Thanks
DesilDesil
Samsung A15 4G for most balanced and reliability
Redmi Note 13 4G for camera
Poco M6 4G for even more budget camera, same as RN13 cam
Poco M6 Pro for most amount of hardware (Ram/Storage)
Poco M5s, just M6 Pro but cheaper but with 1 less year support
Poco X5 Pro best performance and decent cam (still available on Lazada, but just a little over $200, 11.11 maybe?)
ckunjie
If you’re looking for a solid Android phone under $200, I’d suggest the Moto G Power or the Samsung Galaxy A03s. I’ve used the Moto G in the past, and it had great battery life and decent performance for basic tasks. The Galaxy A03s is also a good choice, especially if you want something user-friendly.
chooyoshi
Both are already outdated. Moto g power isn't avaliable in Singapore
machoguy02
Poco c65 8gb ram 256gb memory at $149
Is that sufficient for elderly to use?
usage for YouTube / Facebook browsing.
how much ram is actually sufficient? Aka phone doesn’t lag
DesilDesil
C65/C75 not really that good, cpu is slow more importantly it has slow emmc storage
More ram isn't really going to make phone faster, more ram let you run more apps simultaneously
6GB is enough for simple task, but need to disable xiaomi's ads/add-on service
Can try for this phone(early bird price though, 2.2 sale maybe)
Better cpu, better storage type
Screen type, 1080p resolution, camera, charging also better if that matters
It's more or less a M6 pro with different camera, which is also as low as $140~170 on sale
machoguy02
Thank you for this..
From the shortlist below, which cpu do u recommend:
1) Redmi 14c - 8gb RAM, 256gb, $169, Aug24 release
2) Poco c75 - 8gb RAM, 256gb, $169, Dec24 release
3) Poco m6 - 8gb RAM, 256gb, $185, Dec23 release
4) Poco m6 pro - 8gb RAM, 256gb, $196, Jan24 release
froztheart
Look at the CPU/Storage (UFS 3.0 & above) and lastly RAM to zoom down on your choice.
DesilDesil
m6 pro the better out of those
machoguy02
Are u referring to Redmi note 14 4g or 5g?
4g is using g99 whereas 5g is using Dimensity 7025.
I didn’t realise there were two versions.
DesilDesil
The one in picture is Redmi Note 14 4G
5G is much more expensive and unless you really need the 5G network connectivity, the other upgrades are quite minor and infact have some weird cons
8-lane
If anyone looking to buy Redmi Note 14 5G... dun buy from the official channels... buy from resellers cheaper...
machoguy02
I’m camping for this but 4G after advice from various hwz bros.
Do u have a link to those resellers? Do u mean mister mobile?
machoguy02
Thank u.. I’m eyeing the 4G 8gb RAM so at least the elderly can use it for a few more years
DesilDesil
The early bird steep discount only for 6GB iirc
Can try luck on 2.2 for the 8GB or the M6 Pro
Xiaomi official site was the $179 above, got vouchers need play with
Shopee with shop stack with platform voucher might match
Lazada vs Shopee for Xiaomi phone price is see mood, somethings one side cheaper sometimes the other
machoguy02
I see Xiaomi official website for note 14 4g is now $199 (6gb ram) and $249 (8gb ram).
a few Lazada shops is selling the 8gb ram at lower prices:
- Univercel global $225.50
- speed mobile club $232.50
- gadget affair $235
Are they authentic new local sets? Anyone knows what’s the catch here?
