Good quality internet radio for bedroom
Vassago
Dear Masters,
Do you have any recommendations for good quality internet radio player with alarm for bedroom?
Use case
1. Listen to Radio via Internet
2. Limited shelf space , so need to be not too big
3. Alarm
4. Decent or good sound
I saw Nuark. It is kind of pricey.
Any other brands I can consider?
Thanks in advance
caterham7
Dear Masters,
Use case
3. Alarm
Thanks in advance
can consider using an existing/old phone, and pair it with bluetooth speaker
joesph
google nest wifi point (non router), it has super sounding speakers and can use voice commands, maybe two points can stereo haven't try. jbl horizon 1 & 2 shouldn't be smart speaker
joesph
Dear Masters,
Use case
3. Alarm
Thanks in advance
nuark? link?
joesph
tunein doesn't have some stations in this part of china, and this station doesn't have a website/or stream available i think
obichacha
Sonos era 100s, come with alarm and Sonos radio all day long. Wifi control with phone apps.
AirPlay2 with Bluetooth enabled
thretiredDad
Apple Homepod/Mini or Amazon Echo/Dot should fits well.
This homepod
sometime will get on my nerve
recently a few local radio channel
disappeared under tunein
cant even play from Home-Pod
I couldn’t find xxxxx from your Apple music library
how to solve it?
airplay From iPhone to HomePod is not an ideal solution
ended all voice message will be played on HomePod too
