Oppo Find X8 Series
hstreamy
How to turn on ai speak? Seems can't find the option thou...
Edited: can be found inside smart bar..is called voice translate
vibranze
Chinese phone always have this clean up storage, optimize memory thingy, don't know it's a good or bad thing 😕
Also I found out the summariser and some other AI stuff failed to process, any of you encounter the same issue? Is it because of the apps are trying to connect to China server or something like that?
vibranze
Same, waiting for price drop then can replace my X5 Pro
I found the Oppo X3 Pro design the best, particularly the white version, the unibody design is just awesome. And X3 Pro was a 2021 phone, now we are at X8 already, the phone tech development is damn fast.
sibeiTrolled
Haha.
They skipped the 4 and 6/7 was china only release. Probably that's why it felt so fast
Purchased my 5 in 2023 after hearing the 6 was a china only release. Some regrets as it was the 8Gen1 hot boi, hopefully this new dimensity 9400 is good.
Really looking forward towards 2025 once my self impose limit of 2 years is up, then can go molest the X8 / X8 Pro depending on price
Alexz_Hong
just saw this on gsmarena.... USB 3.0 for global Find X8 legit? the specs page doesn't mention it at all, just say "USB Interface: Type-C" for the Find X8, whereas they specifically say "USB Interface: Type-C, USB3.2 GEN1 supported" for the Find X8 Pro.
https://www.oppo.com/sg/smartphones/series-find-x/find-x8/specs/
Alexz_Hong
Only pro support video output
yeah. seems like it from what I could find on youtube. but at least if it legit supports faster transfer speeds compared to CN version which is USB 2.0, at least would make more sense for a phone like this. :ROFLMAO:
sibeiTrolled
yesterday, ask westgate opp abt trade in program.
X5 pro trade in, off set $216 or $218
Thanks.
Still more than or around 1k though..haiz.
Very painful now that phone prices almost the cost or more expensive than that of a normal laptop
eddy0505
If don't care about local warranty or rely on those shopee shop warranty (reputable ones), I will just take china set if the cost difference is big.
