Starhub UltraSpeed 3Gbps/5Gbps/10Gbps plans
temasek7
Then Just put the router near the centre of the home and at a higher position a single router should do the job. The most add an extra router 710 but unlikely. My 4 room whole house 1 Nokia ONR already can cover. Unless your router location no good and the router is at low position.
Ok, i think should be consider high (head level) and near middle.
but then do you know if EB810V and HB710 signal coverage range? Wondering if should change to HB710 instead and save some money.
flowerpalms
pls teach me haha
I just said I don't want the routers, only want ONT, and said I will switch telco
what other reason can I use?
Read HWZ Forum Rules!
Last time I went to the shop, the CS dun even want to sell me the $29.55 plan. Recontract is the $45/month for ONR. Then I just show him the link and nego loh. Show that you really keen for the cheaper plan although is for new sign ups. But he only sell me ONT, ONR cannot
Henry Ng
Not so sure about range but my flat use one Nokia ONR already can. Now i already got upgrade to EB810v from Tech Support. Also cover whole unit.
Henry Ng
He can use back your method.
ahboon83
the CS checked my plan and still said cannot recontract at $29.55
maybe because I'm on cheapest $30 500mbps plan now haha
Can use Asus as main router and Beacon 2 as wired AP.
This ASUS must switch to 160 Mhz then it will be faster and get 1500mbps on wifi 6 laptop.
For internet speed, RT-AX82U is limited by the WAN speed of 1Gbps, so it is not possible to achieve > 1Gbps Internet speed over WiFi or wired connection (wired speed is also limited by the 1Gbps LAN port speed limit).
In order to achieve >1.5Gbps WiFi speed over the internet, the wireless router needs to have >=2.5Gbps capable WAN port.
Your previous Nokia XS-2426X-A ONR and current EB810v have 10G WAN port, so that you can get >1500Mbps wireless speed.
I just tesed with ZTE BE7200 Pro+ (2.5G WAN/LAN) with my Acer Swift 3 early 2021 model with Intel AX201 WiFi 6 adpter at about 3m distance. I can see the PHY Link speed is 2402 Mbps. The download speed is >1.6Gbps (1621.78Mbps) but upload speed is only at 1.1Gbps (1103.38Mbps).
https://www.speedtest.net/result/d/545f810e-ee37-4c99-86d1-d2ba305b0d12
flowerpalms
All I can say is there are limitations and also depend on CSO
If you get those CSO that is law by law and go by the book, maybe find other CSO instead or go another shop
Usually those CSO in the shop are the same few ones who handle broadband customers
gnixer
search taobao high and low for asus XT8 model, seem like very hard. heard the seller says no more in production. dilemma between xd4/xd5 or xt8 or bd4 to replace lyra trio.
Henry Ng
Such wifi speed is up and down la. I ever tried with Linksys MX 2 and i got 1500+ DL and 1200+ UL about 3m too so may be asus also same la.
That is not possble, do not anyhow say.
Linksys MX2 has only 1G WAN port.
https://www.starhub.com/personal/broadband/routers/smart-wifi-series.html
Type of router
Smart WiFi
Nokia Beacon 2
Smart WiFi MX2
Linksys MX2001 Velop
Smart WiFi Pro
Linksys MX4200 Velop
TP-Link EX510
WiFi StandardAX / WiFi 6AX / WiFi 6AX / WiFi 6AX / WiFi 6
Max WiFi Combined Bandwidth1,800 Mbps
(Dual Band)
3,000 Mbps
(Dual Band)
4,200 Mbps
(Tri Band)
3,000 Mbps
(Dual Band)
Concurrent Transmission Streams2.4GHz: 2x2 @ 40MHz, up to 600Mbps
5GHz: 2x2 @ 80MHz, up to 1200Mbps
5GHz: 2x2 @ 160MHz, up to 2400Mbps
5GHz: 4x4 @ 80MHz, up to 2400Mbps
Internet WAN Port1Gbps1Gbps1Gbps1Gbps
10Gbps LAN Port----
2.5Gbps LAN Port----
1Gbps LAN Ports1334
USB Port--11
Recommended minimum number of units based on housing type
  • 1-2 bedrooms: 1 unit
  • 3-4 bedrooms: 2 units
  • 5 bedrooms: 3 units
  • 1-3 bedrooms: 1 unit
  • 4-5 bedrooms: 2 units
  • 5 bedrooms and above,landed & multi-storey home: 3 units or more
  • 5 bedrooms: 3 or more units
no choice want to use it a node as it is compact. or else change the whole setup to xiaomi or tplink HB710 walk in buy 3 units from starhub using my in law account.
Anything should be better than Lyra Trio (dual band AC1750).
Are you tring to use Ethernet backhaul or wireless backhau? Triband is better for wireless backhaul but they are not cheap.
If you can use Ethernet backhaul (got LAN ports in the rooms), then you have more choices and you can go with dual band routers.
BTW, I do not recommend ZenWiFi XD4/XD5/XD6 as the main router myself. It is better to have one stronger one like TX-AX6000 as the main AImesh router and then add XD4/XD5/XD6 as AImesh mesh nodes if you can use Ethernet backhaul.
If you can use Ethernet backhaul, you can also consider Asus TUF-BE6500 + ZenWiFi BD4 combination.
