crimsontactics
- Nov 25, 2009
We no have Bro Ghost_is_here...I prefer AK47
We no have M4s in moi unit Bro Courage...M16 is superior. If you find it too long you can use carbine. It's so light
The ones moi use ish the very old version leh Bro parchiao...SAR21 is like our paper generals, none are battle tested.
M16 is battle tested and modified to address issues since it was called AR-15.
We no have AK47 Bro popdod...Not AK47 ??
I play CS. AK47 can headshot wan![]()
Even doing combat shoot or combat movement when u need to hold the gun on standing position u can easily hold m16 much longer....Moi CPL only, so only march 24km before Bro Jian19...![]()
Really meh Bro Jian19?Even doing combat shoot or combat movement when u need to hold the gun on standing position u can easily hold m16 much longer....
Sar21 quite bulky too, very easy IA if u shoot blanks
My era is m16, never use sar21 before
So moi enlisted on 2011...
During BMT and medic school, we use SAR21 to train...
Very good gun, short short so easy to move around, then got scope so very easy to shoot...
Some more charging handle by the side so easy to pull...
Then moi got posted to Air Force and we are forced to use M16 because we are considered rear units...
The M16 so long move around so mafan...
Then the iron sight so jialat so hard to shoot...
Charging handle also at the back which make it hard to pull...
But why so many old bird said M16 better? Is it nostalgia?![]()
Like hold the gun with both arms on stand guard positionReally meh Bro Jian19?
SAR21 shorter easier to move imho leh...![]()
M16 where got good Bro zyklon86?M16 is genuinely good.
Light, reliable, easy to maintain and no need scare people steal the regulator.
Sar21 also good, but it is heavy and not designed for an army that is trained to tekan each other.
Actually I only hate sar 21 because I feel that it is just a conversion to help turn state money into private money through ST. You know you know.
Hmm? If you are in your early 50s, you should have used SAR21 in your ICTs.
Chiu SPF or SCDF Bro trax06?Sorry cannot help you. Nvr handled both before.
Moi use both before so can give honest opinion Bro TakKiu...I use M16, never use Sar b4 of cos i say M16 good la. Vice versa.
M16 not tiring meh so long Bro Jian19?Like hold the gun with both arms on stand guard position
I hold sar21 for 5 mins my arm bukeyi liao
Chiu SPF or SCDF Bro trax06?![]()
