Nuclear Boy
- Dec 19, 2009
M16 is longer, but lighter than SAR-21.But if not going war and only wayang, then the fancier, lighter, shorter weapon, IA all the way is still ok.
Weight, rate of fire (on full auto), magazine placement, sub-optimal handgrip position (esp if you're a smaller person than design avg)What are the drawbacks Bro Nuclear Boy?![]()
Heavier is a poor choice unless the weapon is more robust and has greater firepower.M16 is longer, but lighter than SAR-21.
Minor plus point would be less muzzle rise due to recoil, counteracted partly by the addtional weight.Heavier is a poor choice unless the weapon is more robust and has greater firepower.
Moi know, but tiagong their marksman criteria ish harder cos their targets are further away Bro Nuclear Boy?They are just a member of a regular infantry section. They are not snipers.
SG so liberal de Bro Nuclear Boy?Yeah, as long meet the minimum height requirement to fire from foxhole position. Each hole got a spec beside to supervise and assist de.
Sian ish good as a NSF Bro deathan9el...sian right?
can't even learn how to pilot a fighter jet
wasted
but everyday can book out, k laa
Your sergeant allow chiu to shoot full auto Bro Nuclear Boy?Weight, rate of fire (on full auto), magazine placement, sub-optimal handgrip position (esp if you're a smaller person than design avg)
I think biggest drawback is that it can't use standard STANAG magazines like on M16, in terms of logistics. We still have M16 in use, plus Ultimax SAW, all share the same mag (SAW got extra holes punched, but otherwise can still be used in M16).
I don't think so. I could be wrong, but I think they're issued a bog standard SAR-21 like everyone else for marksmanship session to make it fair.Moi know, but tiagong their marksman criteria ish harder cos their targets are further away Bro Nuclear Boy?![]()
Moi never used before Bro Slowdown...Moi only use AR15.
But tiagong the sharpshooter's SAR21 got 3x scope Bro Nuclear Boy...I don't think so. I could be wrong, but I think they're issued a bog standard SAR-21 like everyone else for marksmanship session to make it fair.
Moi never shot full auto before...![]()
"You might very well think that. But I couldn't possibly comment."But tiagong the sharpshooter's SAR21 got 3x scope Bro Nuclear Boy...![]()
But chiu not scared lose control then pew pew other ppl meh Bro Nuclear Boy?I did it secretly during a live firing range session. Everyone also firing away, PING-PONG-PIANG-PING-PONG-PIANG~, the supervising officer also cannot tell.![]()
Moi thought this one ish open information Bro Nuclear Boy?"You might very well think that. But I cannot possibly comment."![]()
RSAF chiu what vocation Bro 5adisticD3vil?bmt only m16
after that rasf no range![]()
Those using AR15 should be Grandpa grade liao.Moi never used before Bro Slowdown...![]()
They deem it safe enough I guess. All the rifles are chained up on the spot too. Can only fire while it's rested on sandbags.SG so liberal de Bro Nuclear Boy?![]()
I'm not sure, but just in case.Moi thought this one ish open information Bro Nuclear Boy?![]()
