Section sharpshooter / law gunnerWhy your m16 got scope de Bro PaboJames?![]()
Yes, just ask John Wick and his pencil...in before, any weapon is a good weapon![]()
No leh, I reservist go fam course, strip halfway until the bolt I blur already, maybe it's the debuff la or I gained the "reservist +100% laziness" buffSAR21 also easy to strip mah Bro Eddedd...![]()
US loses the Vietnam war
Why leh Bro zeozoe?I personally found SAR21 less accurate, although scope easier to see the target. Trainer tell me factory zeroed, but I aim and shoot dunno why never hit. Good thing is the SAR21 I was issued was new, so much less IA.
My M16 more accurate after zeroing, lighter, and better balanced.
That ish very true Bro Jurchen King!I used M16 as NSF but SAR21 as reservist. Preferred SAR21 due to targeting scope. Could shoot and score way better than using M16.
But why must chiu roll on muddy grounds Bro Caterpillars?After rolling on muddy grounds, my SAR 21 scope can't be used at all. Can only shoot bird.
I don't have such problem with M16
When comes to shooting SAR21 ish better Bro Devilsire...Trained with both.
If in war or for live range, i'd pick sar21 for the ez mode shooting. M16 much harder to zero and terrible to rely on its frontsight tip for night shooting.
For training, definitely m16. Lighter, less bulky, easier to secure, easier to sling with comfort
That ish very true Bro XCalintz!Correct. SAR21 technical handling is so easy that even after NS, still can remember in ICT.
SAR21 technically wont IA if the rifle is clean. IA can happen in M16 way more commonly.
Worst weapon to handle is GPMG. Heavy, dirty, more complicated. The only enjoyable part is shooting it from the hill.
M16 iron sights shoot bird de Bro lalalalalala!prefer m16. sar gets problematic once the barrel heats up. your accuracy etc will be affected. also sar21 scope not consistent one, need to keep recalibrate and will dirty / fog up especially if u wearing glasses. i found myself more consistent with the m16 iron sight.
Most of us are right handers Bro Enola88!Sar21 not for left hander , ligther , less recoil and lesser accuracy than M16.
used to M16 liao u wont get use to Sar21.
Power lah Bro PaboJames!Section sharpshooter / law gunner
Maybe chiu not enough practice Bro Eddedd!No leh, I reservist go fam course, strip halfway until the bolt I blur already, maybe it's the debuff la or I gained the "reservist +100% laziness" buff
I meant outfield scenariosBut why must chiu roll on muddy grounds Bro Caterpillars?![]()
I see Bro Caterpillars...I meant outfield scenarios
Which one chiu talking about Bro mryang?Easy for maintenance purposes also
