Haha, you are really into this 2GB RAM thingy.
I am also very much particular about the CPU used and the amount of RAM used.
Asus usually publishes the RAM and Flash size, but no details about the exact CPU used (but easy to guess based on the description of the CPU).
For WiFi 7 routers, TP-Link does not publish the info about CPU, RAM size and flash size. They actually mention in their forum whether to publish such info is a business decision.
For EB810/HB810, I tend to believe that the initial versions may have 2GB RAM installed (based on earlier teardown reports). However, later production may only have 1GB RAM installed. Most of the users may not know anyway. And even if the users notice the RAM usage is 50% or 60%, that is perfectly fine anyway. Only if it is reaching 90% you may need to be worried.
Asus FW is more complicated and I guess they may consume more RAM than TP-Link. That does not prevent Asus to use 1GB RAM for lower cost models like RT-BE86U (single 10G ports and quad 2.5G ports) and ZenWiFi BT10 (dual 10G ports).
