CFC
- Jan 12, 2002
Hi. U have the link for this plan? Can't seem to find it one SH website.do consider the Starhub 5Gbps plan at 29.55 if you're looking around.
Seeing M1 Facebook and reddit horrible customer service, can help share how to successfully end my broadband contract with M1 ?
My contract end date is 28 Feb 2025 but billing cycle is from (11th of current month to 10th of next month). When should I start engaging them to end contract? And will there be prorated refund?..
Thanks![]()
How to change #3 and #5?Asus China version has both Chinese and English UI.
https://forums.hardwarezone.com.sg/...-tuf-ax5400-rt-ax5400-and-tuf-ax4200.6315347/
2. Note: Asus China version vs Local version
They are basically the same HW and same FW, just different country code. The country code can not be changed as it is outside of the FW area. The country code will decide the minor differences in the behaviours.
Major difference:
Local version has three years HW warranty. China version will have no local warranty.
Minor differences in terms of FW behaviours:
1) China version has Chinese/English Web UI
2) China version may have specific game accelerator (网易 UU 加速器), just ignore it.
3) China version may ping Baidu for web monitoring but you can change the behavior.
4) Some China version routers may have special Web UI skins like Asus TX-AX6000, which is a bit different from local version TUF-AX6000.
5) China version has wireless region default to China, but you can usually change to Asia region to be compliant to local regulation.
6) Some reports say that Asus Instant Guard VPN may not work with Asus China routers.
Once you buy the router you will know.
An exception for #5 is TUF-BE6500. Current FW only allows selection of China (lower TX power) and Australia (higher TX power) region for wireless. I tend to believe future FW will fix it.
can cancel m1 bb through its chat handphone. dont need to return modem.Just sharing experience... went to Nex M1 shop to cancel broadband and port over fixed line number....
M1 shop does not do cancellation.... Advise to call 1627 to do it...
cannot cancel broadband first if you want to port over fixed line number to your new service provider...
starhub can remove the promotion anytime it wants. after 2 years, maybe the promotion no more already.do consider the Starhub 5Gbps plan at 29.55 if you're looking around.
not aware of a chat handphone. the lady says only call online..can cancel m1 bb through its chat handphone. dont need to return modem.
Currently using M1 500mbps @$30+. if I were to change it to viewcomms 2.5gbps @ $24/mth,
any catch I need to consider? Or is an obvious upgrade?
Thanks for the advice, I'll try their online live agent 1st (just to make sure there's black and white). Went to M1 shop and the staff attitude are terrible, brushed me off saying "we don't do termination here". But they can do recontract lol.advise to give more than a month notice,roughly from 20 Jan 2025 to M1 BB hotline, get confirmation of the CS that she /he has noted the termination of contract on 28 Feb 2025.
some m1 shops dont do termination. like last time i went to west mall shopping centre to cancel internet. they also said they dont do termination there, then told me to go to jurong east imm shopping centre to terminate internet. m1 is alot more expensive than whizcomms. last time i subscribe to m1 500mbps price plan because it is cheap $30 per month. now its cheapest price plan is $35.90 per month. see no point hanging on with m1 anymore.Thanks for the advice, I'll try their online live agent 1st (just to make sure there's black and white). Went to M1 shop and the staff attitude are terrible, brushed me off saying "we don't do termination here". But they can do recontract lol.
so you jumping to which one?i used m1 500mbps price plan from year 2008 until now, finally going to terminate the internet in 25/4/2025.
