Nvidia RTX5000 up to +30% better than RTX4000 (only!)
final1
I don't know where this screen caps originally came from, in this reddit post, but 28/20 = +40% improvement in rasterization + RT?
2.5X (+150%) improvement stats is only possible with FAKE FRAMES generation.
The point is that the user can't tell the difference whether it is frame generation or not.
They just see higher FPS.
And, that's all the want.
Its not relevant to the user whether its generated frames or not.
Chevalier
on the contrary. it will matter to the more discerning users who want the best quality and also the lowest latency. without a doubt, there will still be some latency introduced when DLSS is on.
final1
For those 1% who want to examine every single pixel for ghosting or whatever, nvidia doesn't care. Those people can accept it or not. Up to them. Nvidia has decided this is the way to go. Buyers can buy it if they want. Or, don't.
fkchon
Biden administration is an absolute train wreck. Hopefully Trump will undo this policy.
Koenig168
Joe Biden wants his administration to be remembered for having done something positive.
Unfortunately, his term will be remembered for a disastrous start (being chased out of Afghanistan), an insipid middle and a humiliating exit (senile and too stubborn to quit early).
final1
Damn.. I wonder if this would affect 5080 price?
its ok. We are not getting 5080 or 5090 FE anyway!
So, SG pricing is not relevant. You will have to buy from ebay or travel to USA (or some other country. Taiwan?) to buy it.
Ignore all the AIB models which are all inferior compared to the bespoke 2 slot design from nvidia itself. Nothing compares to their 5080/5090 2 slots! Not 2.2 slots. Not 2.5 slots. 2 slots exactly.
ragnarok95
Senior Moderator
Senior Moderator
We can easily move ourselves to the same tier as Japan/SK etc. It just depends on our gov.
Yakumo
I think there's 3 slots or slightly under 3 slots card with the SFF versions. Aren't 2 slots but it's the best we can get. I'm worried about the temperature tho..
final1
As they are not 2 slots, they are clearly inferior to the FE. No contest.
No innovation.
R6exR6
kappak
