Steyr69
- Oct 7, 2006
Bad luck had fallen upon me last week.
I find I can't power up my PC. Previous night still working fine.
Then next morning I power on, the CPU fan spins then stop....I tried a few times also same.
And after that, completely no spin.
Suspect is Power button failure, I use the screw driver to short the 2 pins on the board.
But no response.
I proceed to check PSU, but looks to be working. The board actually have RGB lighting on it, so I can see there is lighting.
I also use the paper clip testing on the PSU, and no issues with the fan spinning.
My specs:
AMD Ryzen 5600G + TUF GAMING A520M-PLUS WIFI
AMD Stock cooler
Andyson 450W PSU
Crucial Ballistix 3200 8GB x 2 ram
Crucial 2TB NVME SSD (Primary Boot Drive)
Link More 480GB SATA SSD
I bought the CPU and mobo combo in Feb 2023. Assembled and working since then until last week.
Main usage is surf web and video editing. Usage everyday is more than 12 hours.
Play some simple ArmorGames.
No overclocking.
Knowing there are 2 distros for Asus, I called up Asus CS hotline to hilight my issue.
The guy informed me to send the mobo to Avertek.
I also confirm with him my mobo is still under warranty. He asked for my mobo serial number and I provided him.
So, I dismantle everything and bring the bare board plus box and invoice (I bought from Dynacore SLS) To Avertek.
The CS guy told me there is no need to make any prior appointment, can just go directly.
I met this Avertek guy and he did a thorough visual check on my mobo with a magnifying glass.
He pointed out to me a small white color chip near the CPU socket was very dusty.
He claims that if there are signs of oxidation, the warranty will be void.
He told me he is unable to test the board for me as there is a danger of the board damaging his CPU.
Then he told me he will be sending the board to Asus for further analysis. Not sure Taiwan or China...
It will take approx 4-6 weeks but might be longer due to CNY.
Now thinking back, maybe I should have gone to Ban Leong instead.
1. I would like to understand more on the oxidation part and thus voiding of warranty.
2. In the case, Asus decide to void my warranty, what are the alternatives?
3. Can recommend another budget mobo based on my usage in case there is no replacement. I would prefer a matx, 4 ram slots and wifi connector.
A little info
As I was dismantling the stock cooler, I find the paste pretty dried up. Could this be a reason?
I got this cheap Deepcool ICE EDGE MINI FS V2.0 cooler which I used on my old AM3 system. The website claimed the cooler can be used on AM4. Anyone have experience using this on their AM4 ?
All inputs will be much appreciated.
Many thanks !
But no response.
My specs:
AMD Stock cooler
Andyson 450W PSU
No overclocking.
A little info
Many thanks !
