- Sep 16, 2018
can check with you, what type of ram or ssd they are using? say if i get 8 or16gb and their ssd? is it reliable ? else get my own brand like crucial ram and my own ssd?
i think i get 2.5G, no point getting 10gpe, even the switch is so expensive and my nic also need to be 10g and i have no plan to get fiber 10gbe, only the cheapest plan, maybe simba 10gbe when my m1 500 plan is force by m1 to change plan or starhib brought over m1, but it will be cheapest ont plan
they have 2 version, which one is better QC?
https://detail.tmall.com/item.htm?id=719772687903
https://detail.tmall.com/item.htm?id=714619184058
many thanks
1. The recommendation is to get the bare-bone version if you want better reliability. I have not opened the two CWWK Intel N100 boxes I have to check myself, but I do not think they will use very good one because of the pricing.
I have opened the previous Intel J4105 mini PC (8GB, 256GB, not from CWWK though) I used between early 2021 to late2023, it is using no-brand SSD and RAM.
2. Pricing of 10G switches from China brand are pretty okay now (S$100 to S$150 for 8-ports SFP+ port; S$160 to S$300 for 8-ports 10G RJ45 ports, something in between for 4+4 mixed version ), 2.5G/10G switches are even cheaper (S$30 to S$50 for a switch with quad 2.5G ports and two SFP+ ports).
https://forums.hardwarezone.com.sg/...and-switch-rj45-version-no-sfp-ports.7072646/
https://forums.hardwarezone.com.sg/...port-switch-and-vq-xgs-pon-onu-stick.7047645/
3. The three CWWK versions (先锋版 vs 精英版 vs 锋尚版) should be quite similar in terms of Quality Check. But the features are a bit different.
I bought the Intel N100 先锋版 16GB/512GB for RMB 1560 (now cheaper) in Sept 2023 and it has been running stable since Oct 2023 and 24x7. But I will recommend 精英版 now as it has better interfaces configuration (eg: USB 3.0 ports). When I bought it, there was no 精英版.
I have another CWWK Intel N100 -- X86-P5 (16GB/512GB version at RMB1289, now cheaper) which was bought at the same time and it was also running 24x7 since Oct 2023 to now.
At that time I did not expect XGS-PON based plan to drop price so fast in 2024, and I was waiting for true 2.5Gbps plan to be launched to replace my Singtel 1Gbps plan (contract would only expire in August 2024). So I invested quite a bit on the 2.5Gbe stuff, including a TP-Link 8-port 2.5Gbe switch and later a few 2.5G capable China WiFi 7 routers. I have to invest quite a bit on 10G stuff this year and I think I could have saved some money on the 2.5Gbe stuff and use that fund for 10Gbe stuff. But anyway,
You may want to check out the differences between the three versions: 先锋版 vs 精英版 vs 锋尚版.
4. There are quite some other choices, CWWK is just one of them. You may want to check them out as well.
5. Miniroute R1 Intel N100 version is the one I am using for my Singtel 5Gbps plan. But it has some quality issues -- one of the 2.5G port is dead now. I did not open the box to check what is the problem. But initially I also encounter other issues -- WiFi 7 adapter did not work and the vendor is saying that there is BIOS issues. So you may want to avoid that one since it is also being sold by CWWK and a few other shops, as being the cheapest 10G capable Intel N100 mini PC.
https://miniroute.com/products/mini...pc-2x10gbe-ports-portable-soft-route-computer
