Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    205
Conway
QC lousy. Can see some swirl marks after I removed the factory screen protection film. Tried to wipe with lens cloth but doesn't go away...
Apart from that, I can see the fingerprint sensor under my light in the middle of the screen.. Anybody else can see? It's a square shaped under the screen, when the screen is off. Place phone on table and look direct reflection under the light.
Found a video of someone else seeing the same thing 😂
https://www.instagram.com/muthuragavansivaprakasam/reel/DFhJl9iszuI/
this is normal for FP sensor. its been there all along. even my s23 can see. lucky not very obvious :o
camoguysg
My order status finally changed to on the way....but I had two missed phone calls just now : 66820591 .... did anyone recognise this number? Can't be from the courier right?
ahtea
Is it pre order or normal day?
Pre order is the same. You can schedule pick up dates to go to Apple Shop to collect.
If there are no more stocks left, they will mark item as unavailable or tell you the estimated date which is quite accurate.
Fellowes
Both reach around 10am today, east region.
Base S25 with SMS and waybill
S25U with SMS, waybill not found in SF Express system.
Samsung Shop app still indicating as on the way.
SyraLeo
Collected my phone, I chose Feb 9th but my order page said ready for pick up so I tried my luck.
Collected from north point.
