Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    204
gws898
To see which colour you buy have to see on the top of the packaging instead of the front packaging which previous galaxy used to do.
username03
Doing smart switch to transfer files now via wired. Seems more stable and faster than wireless if anyone is doing the same.
Accessories arrived and applied. I'm using Ringke privacy tempered glass. Easy to apply and no dusts, with the kit supplied. Been using Ringke case and screen protector since s21 days. So far every year I buy the same brand and 1 case use till I upgrade yearly.
SECTORTWO
Using ESR tempered glass. Installation is easy and the glass is very smooth. Fingerprint scanning not that good though.
gwzc_mk2
Using ESR too. Easy to install and no bubbles. Mine quite sensitive for finger print scanning
