Starhub 3gbps and 5gbps broadband price discrepancy
EliNehe
Hi, the retention team offered me when I wanted to terminate my 1gbps plan with the mentioned plans in the subject title.
3gbps is going for *$42/46 per MTH whereas 5gbps is going for *$29.55/$33.55.
*Depends on ONT or ONR.
Anybody finds something amiss? The 3gbps deal is only offered by the retention team Nd not a public plan.
Please advise. Am not a very tech-savvy person,so pls bear with any stupid qns that I may ask.
EliNehe
Didn't know SH have a 3Gbps plan too.
If they have offer for it to be cheaper than the $29.55 5Gbps ONT plan, I would seriously consider it too.
The 3/5/10Gbps plan should be using the same ONT/ONR.
My guess is...if the 5Gbps plan has issues, the 3/10Gbps should have the same issues.
They are just speed difference.
Just had my SH 5Gbps ONT plan setup last week.
So far so good.
My ST 1Gbps plan still active, so I have a backup in case the SH fibre has any issue (I hope not).
Hi,how's the SH 5gbps plan so far??
EliNehe
Hi, so far so good.
Still using with old router, so limited to 1Gbps WAN speed.
Hi, as long as you don't mind, I guess it's all right, cos u can always upgrade the router to a 5gbps compatible one.
Actually I am also thinking of doing the same as you since my main goal is to upgrade my very old modem.
Thanks
EliNehe
Oh, do the ONR issue still not fixed.. that is actually what a Starhub technician told me when I called in Oct/Nov last year.
So the plan so far so good??
Are you using the 1gbps or 5gbps router Starhub offered?
For 1 Gbps router, the retention team offered $29.55 ( I guess as their way of compensating for a slower router??)
mage23
Hello brother, I'm using SH 5Gbps ONT $29-$30ish,
so far so good, actually impressed with SH's low price for 5GBPS yet have freedom of Port forwarding, firewall, can setup smart home also, can use power user's equipment's whenever, yada yada..... Furthest room with Lan connection is like 2ms pinged to google servers. If you want take same plan as me, you can copy my setup....
All equipment meshed with TP-Link's Aginet via wire backhaul, seamless wireless/WIFI at every corner of the house even in toilet watch drama oso power.....
The requirements....
Make sure you have everything ready such as data points in each room linking to DB/Main Router box.
Every room that needs fast WIFI should have 1x TP-Link HB410 wire backhauled to switch/DB/Main Router + ONT Combo.
My setup currently...
- 1x StarHub's Given ONT
- 1x TP-Link HB710 (Router Mode/Mesh)
comes with 2 ports, 10G Wan + 10G Lan Port
For "Routing" +
What you get: (Living Room WIFI Coverage).
- 1x TP-Link 10G Switch TL-SX105 comes with 4 outgoing ports, means can connect 4 bedrooms via LAN cable/wire.
Note that this one need to buy outside yourself.
To enable HB710 have wired connection to 3 other HB410 found in bedrooms.
- 3x TP-Link HB410 (Access Point/Mesh) comes with 4 ports, 1 Wan/Lan 2.5G + 1x Lan 2.5G, 2x Lan 1G
For "Access Point" mode via wire backhaul per bedroom with 2.5G Capable Desktop PC.
What you get: (Bedroom Direct Ethernet + Bedroom WIFI Coverage).
Total extra one time damage:
1x TP-Link
10G Switch TL-SX105 @ $399/-
3x TP-Link
HB410 Supplied by StarHub @ $360/-
More Details:
Why i choose ONT over ONR?.. sure ONR easier to set up, sure 1 equipment and gao tim, but it locks me out of stuff like port forwarding, OpenVPN, and pretty much any serious networking config... And as many described their experience with ONR give a lot problem also.... Don't even want to talk about other ISPs with ONR, complete mess esp when you cannot troubleshoot yourself, need wait a few days book some cock appointment waste time coz ONR config locked by ISP.....
The nice thing of having ONT is, when internet down, most of the time is user fault, can solve quickly but need to understand a bit of networking stuff luhh.
If in the future you or your kids want play with things like hosting Minecraft server all these, ONT is the way to go..... ONR can never do any sort of these things bah.... Maybe in the future can, idk... But unlikely bah....
Btw, all need to setup yourself...
Starhub Field Engineer will only plug in FTP to ONT and then to the given HB710.... And test if everything is stable and got internet. Thats it. The rest you ownself plug uh... But quite easy luh... Search in youtube how to setup HB410 as access point, and how to plug unmanaged ethernet switches can liao.
mage23
HiHelloBye
good sharing(y)
this is what most people are lacking of...
didn't opt for data points then complain slow wifi:s22:
TanKianW
good sharing(y)
Truth is you can see forumers posting their fantastic, powerful and colorful gaming rig and yet their networking is always an after thought. Networking usually take a back seat in most home setups. To most, networking is harder than building a PC from scratch and networking concepts are like technical jargons. But as I see more and more moving to >1G plans, the demand to learn more about networking and optimizations are increasing.​
How to get the 5Gbps plan from SH at $29?
Try this one.
https://www.starhub.com/personal/forms/hubbing/exclusive-5g-promo.html
