dredd
- May 13, 2002
Basically, endless waiting..."Thank you so much for your patience, Ms. Sand
After checking, your Order will be delivered by starting date 2025-02-19. We do not promise the exact date. However, Once the items are ready for delivery, our delivery partner will contact you for the delivery arrangement 1 days earlier via SMS."
Sad![]()
You bought online colour?"Thank you so much for your patience, Ms. Sand
Sad![]()
The reply from SS,Basically, endless waiting...![]()
Also based on colour, and storageThe reply from SS,
"We wish to inform you that the delivery dates are assigned based on the date the order was made, device color and model. So for orders that were made on the first day of pre-order (23rd January), those orders will be delivered from early February onwards and followed by the subsequent orders batch by batch basis. Rest assured that for confirmation delivery, you will be notified by the delivery partner once the device is ready to deliver."
Really based on date?![]()
Yep. JetblackYou bought online colour?
scarli now carousell already dirt cheap,Basically, endless waiting...![]()
Mine is 512gb titanium silver blue, ordered on 26th Jan. As you said, we won't know. The waiting continues...Also based on colour, and storage
So we won't know exactly, unless someone really goes and compile the data
Oh then cannot cancel and buy from physical storeYep. Jetblack
they change everything .. so hard to find thanks!HomeUp doesn't showup in GoodLock anymore. If you have already installed it, you can access from "More customization" at the bottom of home screen settings page.
Wait how come i no havethey change everything .. so hard to find thanks!
home screen -> settings -> More customizations (it's at the bottom)
I did not (more customizatiom) on bottomHomeUp doesn't showup in GoodLock anymore. If you have already installed it, you can access from "More customization" at the bottom of home screen settings page.
check my comments aboveI did not (more customizatiom) on bottom
i don't see this option even though I had Home Up installed on GoodLock prior to the change.they change everything .. so hard to find thanks!
https://forums.hardwarezone.com.sg/...-its-dressing.7002801/page-186#post-155246762 it is a seperate APKi don't f
thank done itcheck my comments above
