Hi, Can anyone share what is the difference between the TP-LINK Deco BE65 and the HB611-SGST router?
I may be getting the Singtel 5bps enhanced plan and plan to buy an extra wifi 7 router.
THANKS!
Thanks so much xiaofan!!You can compare the spec: basically Deco BE65 is quite a bit better but more expensive. I will only recommend HB611-SGST for Singtel users. No point to get it if you are not using other ISPs (it will work but you may get more cost effective solutions).
Hi Bros, would like to do a sanity check on my setup for the above.
- WIFI is disabled on the Archer router.
- Deco Mesh WIFI is set to AP mode.
- Both Deco Mesh WIFI are on different rooms and make use of the single available network port.
Questions that I would like to clarify:
- Does the above setup works optimally or I need a switch instead of using the Deco ethernet ports to connect more network devices?
- With this layout, does the Deco Meshes considering using Ethernet Backhaul instead of Wifi Backhaul?
- ISPs like MyRepublic or ViewQuest support the TP-Link Archer router?
Thanks in advance.
Hi Xiaofan,1) Your plan should work. No need a switch.
2) Ethernet backhaul.
https://www.tp-link.com/sg/support/faq/1842/
3) No issues with either MR or VQ.
4) But if you have not signed-up the Fibre Internet plans and have not got the wireless routers, there is a much cheaper option to go with.
Sign-up Starhub 5Gbps offer at S$29.55 per month ONT option, then get TP-Link EB810v as main router (dual 10G ports and three 2.5G ports, triband BE22000, to replace your Archer BE550 Pro, S$360) and two HB710 (dual 10G ports, triband BE18000, to replace your Deco BE65, S$192).
You can read the first page of the sticky thread on top of this forum section to see which ISP is best for you. I have included Starhub 5Gbps special offer link in the posts.
[Official] README First! 2025 SG ISP Comparison & Latest Promo Deals!
https://forums.hardwarezone.com.sg/...sg-isp-comparison-latest-promo-deals.6665380/
Hi Xiaofan,
Thank you for your verification. Will check up the ISP deals.
Would like to check if there are any Asus equivalent for both the Archer and Deco which suits my needs since understandably Asus provides more regularly updates to its devices though they are also pricey.
1) My recommended China version of WiFi 7 router now.
a) 10G capable
Using as main router with dual 10G ports and some 2.5G ports. Can be used as a 10G AP as well.
Take note the second 10G port is of SFP+ type so you may need a SFP+ 10G copper module to connect to other 10Gbase-T RJ45 devices, or SFP+ Optic module or DAC/AOC cable to connect to SFP+ devices.
RT-BE88U, BE 7200, dual 10G ports, quad 2.5G ports+ quad 1G ports, BCM4916 CPU, 2GB RAM, RMB 1999 to 2199
Xiaomi BE10000 triband (dual 10G ports, maybe good for 10G plans): RMB1499 to 1599
Using as 10G AP with single 10G port, or use as the main router for 5Gbps/6Gbps plan
RT-BE86U, BE 7000, single 10G ports, quad 2.5G ports, BCM4916 CPU, 1GB RAM, RMB 1799
b) as main router with dual or more 2.5G ports. Can be used as 2.5G AP as well.
Xiaomi BE7000 (quad 2.5G ports, good match for 2.5G plans): RMB799
Xiaomi BE6500 Pro (quad 2.5G ports, good for 2.5G plans): RMB699
Xiaomi BE6500 (quad 2.5G ports, good for 2.5G plans): RMB499
Ruijie BE72Pro, dual band, BE7200, five 2.5G ports and four gigabit ports, launch price: RMB 699
Ruijie BE68 Ultra, dual band, BE6800, quad 2.5G ports, launch price RMB 589
TP-Link TL-7DR7260 BE7200 (five 2.5G ports, good match for 2.5G plans): RMB 599
TP-Link TL-7DR6560 BE6500 (quad 2.5G ports, good match for 2.5G plans), RMB 559
ZTE BE7200 Pro+ (中兴问天BE7200Pro+, dual 2.5G ports, good match for 2.5Gbps plans): RMB 599
Asus TUF-BE6500 (quad 2.5G ports) : RMB 799
Huawei BE7 Pro (quad 2.5G port version, 512MB RAM), BE6500, RMB 699
Huawei BE7 (dual 2.5G port version), BE6500, RMB 599
c) as a lower end main router with single 2.5G port (with at least 512MB RAM), or with lower end CPU. Can be used as 2.5G AP as well.
TUF GAMING小旋风WiFi7 BE3600电竞路由器, single 2.5G WAN/LAN port, BCM6754 CPU, 1GB RAM, RMB 499
TP-Link TL-7DR7230 BE7200 (single 2.5G port), RMB 499 launch price, good Filogic 860 chipsets
Ruijie 雪豹BE50, dual band, BE5000, single 2.5G port, 512MB RAM, launch price RMB 399, lower end AN7563PT CPU
Xiaomi BE5000, dual band BE5000, single 2.5G port, RMB279 lauch price (usual price RMB 329), lower end AN7563PT CPU
TP-Link TL-7DR5160 BE5100, RMB 429 (quad 2.5G ports, 512MB RAM), lower end AN7563PT CPU
TP-Link TL-7DR5130, dual band BE5000, single 2.5G port, RMB 329, lower end AN7563PT CPU
Hi @xiaofan , is the 7DR3630 or Xiaomi BE3600 2.5G better as AP?
Can buy Xiaomi BE3600 2.5G from taobao? No region lock right?
Another question is can 7DR3630 mesh with BE230? Both TP-Link.
Hi @xiaofan1) Yes
2) Yes you can. No region lock for the Xiaomi China routers for basic usage. You can use Web UI to configure it.
The Mi Home mobile app is kind of region locked though. But I do not use Mi Home app myself. Certain more advanced function may need to be configured in Mi Home app and in that case you may have to use Mi Home app in China region (not so sure if you need mainland China mobile number or not).
3) No, cannot mesh with each other. TP-Link China and TP-Link System Inc are two different companies and the product lines are not compatible with each other. I have tested this one myself with Archer BE805 and TL-7DR6560.
Hi @xiaofan
For question 1, which model is better as an AP.
If I buy an AP now, should I also consider what to buy so that I can mesh up in future.
Thank you.
So if I buy Xiaomi BE3600 2.5G from taobao, I'll have to buy from taobao in future for mesh?I will tend to like Xiaomi a bit better than TP-Link China.
Usually you decide which router to go with and then choose the mesh node from the same vendor.
I see, is there a big difference between the local BE3600 and China's version?
Price is lower in taobao of course.
If buy from taobao
TP-Link 7DR3630 will cost $43.10
Xiaomi BE3600 2.5G is $45.84
Both by air delivery.
Guess now is whether to choose more RAM or more powerful CPU.
Is BE5000 similar to 7DR5130?You can always spend a bit more to get Xiaomi BE6500 Pro or TP-Link TL-7DR6560 or TP-Link TL-7DR7260, no need to have such trade-offs. They all have quad 2.5G ports.
Or go with Xiaomi BE6500 which is a bit lower end than the above three, but still have okay CPU and quad 2.5G ports.
But if you really have to make the trade-off, I will say to get 512 MB RAM is more important for this kind of low end stuff. In that case, I will actually go with Xiaomi BE5000, which is only slightly more expensive than Xiaomi BE3600 2.5G version.
BTW, if you use them as AP, then the CPU and RAM are both not that important, especially the CPU.
Is the BE5000 similar to 7DR5130?
ZTE BE5100Pro+ is $68.17.
