ZhouXingXing
- Sep 7, 2008
Hi..Thank you. Reading the 3rd post of page 1 of the thread the correct sequence that I should ask is if I should accept the job then throw the sheng bei 1x, regardless of the result, I should ask another question if I should stay at this job then throw sheng bei?
May I know if the sequence is correct? Thanks!!
you got only 1 offer or more than 1 offer?
if you have only 1 offer, you can follow the example i gave you in my previous post.
Btw if you are not sure whether to accept the job, you may need to review your needs or career first before going to ask Gym as we dont recommend you going to ask without thinking thru (like just ask if you should accept the job) as you may end up with many xiao bei and with no conclusion.
if you have more than 1 offer, you need to categorised them into option a and option b.
so you can ask gym which option is more suitable for you like the steps shared in the 3rd of this thread.
can let us know if you have certain parts not sure
