Unblock TV Discussion Thread III [consolidated]
bumperbee
Mine just happened today - same issue 2nd time. Exactly like yours, first time was fixed under warranty 1 year ago. 3.5 years old TV... don't think I will fix it.
Yes, all mac address are unique so identifying mac address is the best solution.
What about using your own iptv.
Here is how you can have your own iptv and not subject to any restriction.
installed this simple iptv app and you have iptv and also vod.
http://sendanywhe.re/FYA8TWT7
Goodluck and enjoy.
Hi,can upload again please. Many Thanks
bumperbee
Hi, does anyone have a working ThunderX or XunleiX that can download movie torrents from China movies website? Thanks in advance
Philippng
bros, downloading is infrignment of copyright. Now a day, no one will consider download.
Streaming is the option, as long as you dont download you stay in the grey area and so far there is not an issue
ah_cleo
Anyone managed to upgrade their gen 2+ s900 to andriod 5.0? Now upmovie below andriod 5 cannot be use. 🥲🥲🥲
I can only use it for live tv.. not intending to use other app as old folks alr used to this upmovie
shin89
Those with Smart Google TV just need to sideload anboxtv and check out the latest playlist from yogurt and xiaoyun inside anboxtv. one setup in google tv it is as good as you have a tvbox inside your smart tv
Why you keep promoting this?
