- Sep 16, 2018
From my living room lan port > switch, which port do I connect in and which port is out to my devices ?
All four 2.5Gbe ports of the switch are equal, just anyhow use.
@xiaofan If i get the $18 Tplink NG421 does it need driver to run ? Cuz i couldnt find any driver except the iso file which i duno how to install
Hi, my Mercury switch just arrived. However, when I connect it to my 2.5Gb network adapter, my speed is capped at 900Mbps. The green blinking light indicates a 2.5Gb connection, but my other devices, which blink orange, achieve speeds of 900+ Mbps without issue. When I connect my 2.5Gb network adapter directly to the wall LAN port, it reaches 1.8Gbps.All four 2.5Gbe ports of the switch are equal, just anyhow use.
Tried all the ports on the switch but still the sameHmm, that is strange.
You may unplug and plug the Ethernet cable between your network adapter and the switch to see if that helps.
I have some issues with my Asus TUF-BE6500 and the Hasivo 2.5G/10G switch as well -- sometimes it just negotiates at 1Gbps, need to unplug and plug to get 2.5Gbps.
Tried all the ports on the switch but still the same![]()
Hasivo S600W-4GT-2XGT-SE is probably the cheapest you can find. You should look at the price at Taobao 海思视讯 shop and it is only at RMB 699 listed price --> now about RMB 499 in Feb 2025.
Hasivo S600W-4GT-2SX-SE, RMB 219 listed, quad 2.5G ports, two 10G SFP+ ports
Hasivo S600W-4GT-1SX-1XGT-SE, RMB 399 listed, quad 2.5G ports, one 10G RJ45 port and one 10G SFP+ port
Hasivo S600W-4GT-2XGT-SE, RMB 499 listed, quad 2.5G ports, two 10G RJ45 ports
【淘宝】退货运费险 http://e.tb.cn/h.TagwCPy1xtfft6L?tk=OUoQ3qhNKyt MF3543 「hasivo 2.5G万兆上行POE轻网管交换机企业办公猫棒VLAN猫棒网管型」
点击链接直接打开 或者 淘宝搜索直接打开
For more advanced users, Ubiquiti Unifi 2.5G switches can be a good option.
Cheap one: UniFi Flex Mini 2.5G Switch
More expensive one: UniFi Flex 2.5G POE
