Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    206
sushimonster
Is this the 2nd SIM u inserted? I think something changed. From my usage, seems like the name no longer means which Slot.
So if u insert 3 different SIMs, then u can have SIM1, SIM2, SIM3.
Basically, name of the SIM, regardless of which slot u put in. At first, I am also confused. But this is what I understand after some experiment.
I only have 1 SIM. I placed it on the side of the Tray marked "SIM1" and it shows up with the name, "SIM 2" in the SIM Manager.
albel81
If this is the 1st sim u used then I am not too sure.
Based on what I tried, if you insert a sim (that u never insert before), then it will show SIM3. Like, sequential order. And if u insert back your original SIM, then it will show SIM2.
Meaning, dont matter which side of the tray u put. Cos the name is given in sequential order.
At least from what I tried, this seems to be the case.
Unless I am treating a problem as a feature. Haha.
trenzterra
Anyone tried setting up esim without wifi? Not sure why I can't do it now... Last time I thought ok
Your phone will temporarily disconnect from the SIM 1 network to add the eSIM. Connect to a Wi-Fi or mobile network to add an eSIM. If using a SIM card, the SIM card needs to be in SIM slot 1 and be set as the preferred SIM for mobile data.
kashix
You need data to activate to eSIM if your phone is disconnected from your SIM 1.
jess_sy
I thought if you only have 1 physical SIM at SIM 1. It won't disconnect while adding eSIM?
Unless you using dual physical SIM. SIM 2 will be disconnected
Pearce
Seems like Samsung series 50mp camera does not produce much good photos?
Example for S23 Ultra and S24 Ultra.
How about S25 Ultra?
amazingone
S25 Ultra on Singtel firmware being tested for One UI 8
https://www.sammobile.com/news/galaxy-s25-android-16-one-ui-8-spotted-samsung-server/
way_landr
anyone encounter your s25 ultra overheating constantly while its idling or just doing normal things like Instagram, google maps etc? And the battery draining like crazy when it heats up.
Not sure if its the recent update. I updated on the 2nd mar, didn't really take note of the phone for the next couple of days but the last few days it has been overheating easily, draining like crazy sometimes. Sometimes it stays cool like normal.
If its just me, anyone got any idea how to find out what is causing it? I checked app usage, nothing unusual, I installed accubattery, nothing unusual also...
Rxgn
My whatsapp still having issue, some contacts name are not showing up despite them in the contsct list
Unistall and install the app doesnt solve the issue. Anyone have the same prob?
agcken12
Yes, i did encounter after update last friday and sat, sunday was overheating.. then come Monday, tuesday all back to normal after a reset.
4D.TOTO&BS
Used to have but after factory reset and delvik cache reset is ok. Further steps go activate developer options > Running services and see inside. Factory reset is of course last step but fresh install is the safest although troublesome
