New gaming pc from invader
Hello_la
Hi can someone recommend me which one sholuld i buy from invader. My budget is 1.5k
I play game like dynasty warrior origin. Black myth wunong
NightRaven49
can someone recommend me which one should i buy from invader. My budget is 1.5k
around the 1.5k price point, the only pcs worth buying are their r5 7600 + 7800xt builds for about 1.3k, the other options with the u5 245k, b580 or 4060/ti will be slower. u can also opt for the build with the r7 7700, but for gaming there is not much of a difference. if not urgent, may be a good idea to wait for 9070 series launch next week and see what pricing is like for that, the performance uplift should be around 40-50% with the 9070xt vs the 78xt.
Hello_la
So is this one?https://www.invaderpc.com/product/specm12/
Should i get it or get is from sls?
86technie
Invader is by Dynacore, I rather you ask them quote a better spec.
That case is not very good, showcase PC case are more for
looks and aesthetic than airflow.
AMD RYZEN 5 7600 3.8GHz 6CORE/12THREAD
MSI B650M GAMING PLUS WIFI 6E
AMD WRAITH COOLER
ID Cooling FROZN A400 *Better CPU Cooler the CPU can maintain turboboost
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
SAPPHIRE AMD RADEON PULSE RX 7800XT
CRUCIAL P3 PLUS 1TB GEN4 NVMe M.2
Lexar NM790 1TB *This will be much faster than the P3.
SILVERSTONE ET750-G 750W 80+ GOLD
SILVERSTONE LD04 BLACK ARGB TEMPERED GLASS
Tecware Nexus Air Mesh TG
This is an example you can ask shops like Bizgram quote you.
nabil996
Hi if u know build on your own it would be cheaper plus walk in and ask the store they can give you more discount.
nabil996
USD it is 600 for 9070xt and 550(USD) for 9070 so for us is like close to 1k estimate. 7800xt and 9070xt only small different on both cards. 9070xt have 4 more core on Compute and Ray, 8 more core on AI, and last 276 MHz. 7000 series will be cheaper when 9000 stock come to SG.
AMD website u can see the full spec but not price
NightRaven49
the best way to save money with diy is going to different shops, since i havent seen any one store in sls with the best prices for all parts. this means u will likely get an ok deal even after asking for discount, since if u diy and really buy everything from sls, u will spend at least 1.4-1.5k for a similar spec system. u ask for discount on that price, i dont think they would cut it much below invader 1.3k price, might as well skip the hassle and just order from invader directly with delivery (u still have to bring ur pc home from sls if u build there). i would be more than happy to be proven wrong on this, since i havent bought many parts from sls in a while.
except the 78xt and 9070xt are built on different architectures, making such comparisons pointless. amd is claiming big performance leaps with the 9070xt (+40-50%) despite how small the spec changes seem, but lets wait till tmr to see what the actual improvements are like. 78xt stocks seems to be drying up too.
ragnarok95
Senior Moderator
Senior Moderator
AMD WRAITH COOLER
ADATA XPG LANCER DDR5 6000 32GB (16GB X2)
The crucial pro is better than the adata.
ragnarok95
Senior Moderator
Senior Moderator
Actually, ryzen benefits a lot from tight timing. The lower the CL the better, esp CL28. This crucial pro actually performs very well at its timing.
nabil996
So what is your finding with come out 9070xt?
nabil996
@Hello_la OP, i've DM'ed you an offer. I hope its attractive enough
Why 9800X3D , not the 9950X 3D. The 1000W Lian Li cable pin for the GPU need to see what pattern they using Jaytwocent videos show the difference type on the long term effect. I will need to see that PSU. How about the CPU cooler?
NightRaven49
as expected, a roughly 40% uplift over the 78xt, before considering raytracing improvements (closer to double the performance).
9950x3d not yet released. single ccd ryzen is better for gaming anyway as there is no chance for inter ccd communication which incurs a large latency penalty.
Hello_la
cpu : amd ryzen 5 7600 (tray ver)
mb : msi b650m gaming wifi @ $519
ram : corsair vengeance rgb 5600mhz 32gb (2x16gb) cl36 black @ $183
ssd : dynabook ax7000 1tb nvme m.2 gen.4 @ $91
hdd : -
gpu : sapphire rx 7700 xt nitro+ 12gb oc @ $647
psu : cooler master mwe 750w gold v2 gen 3.1 @ $118
casing : cooler master elite 301 argb tg matx black @ $75
cpu cooler : silverstone pf240 argb 240mm aio cooler v2 @ $118
*Total: $1751*
7600 + MSI MAG B650M Gaming Wifi $465
KLEVV C910 Gen4 M.2 5000MB/s 1tb $82
KLEVV FIT V DDR5 6000 CL32 32gb kit $125
cooler comes with cpu
FSP HV PRO 85+ 650W 80PLUS BRONZE $67
Tecware Timber ATX TG w/ 4 Fans $69
SAPPHIRE PULSE RX 7600 XT GAMING 16G $520
total $1328
COOLER - THERMALRIGHT BURST ASSASSIN 120 SE - 3 YRS
CPU - AMD RYZEN 5 7500F 6C/12T - 3 YRS
MB - MSI PRO B650M-A WIFI - 3 YRS
RAM - KLEVV FIT V 6000MHZ CL32 32GB KIT - LTD LT
SSD - LEXAR NQ 700 1TB NVME M. 2 PCIE4 - 5 YRS
GPU - ZOTAC GAMING RTX5070 12GB SOLID - 3 + 2 YRS
PSU - FSP VITA GD 750W 80+ GOLD NM (ATX3.1+PCIE5.1) - 5 YRS
CASE - TECWARE TIMBER M TG BLACK - 1 YR
$1799
Hi out of this 3 which one should i choose?
nabil996
hdd : -
*Total: $1751*
total $1328
$1799
are you going to overclock or change any setting on the bio?
86technie
hdd : -
*Total: $1751*
total $1328
$1799
None just ask them build this which I shared in earlier post.
MSI RTX5070 12G Shadow 2x <- Slight Change
Lexar NM790 1TB
FSP VITA GD 750W <- Slight change
schoool
Why 7800xt Ryzen 7600 was $1325 from Invaderpc becomes M14 $1458:cry::cry:
I thought it will drop price but become more expensive instead.
