RDNA4 RX 9000 series thread (Navi 4X)
Yongkit
dota/ both also having same problem.
revert back to 24.12.1 then normal
i no play dota unable to confirm on mine.
i try cp2077 full screen alt+tab no flickering though i am using hdmi 2.1 full bandwidth on my monitor,
Phen8210
@kappak @Yongkit so far these are the known issues
Anyway quite saddened at the last line to see bugs related to WSL 2, i usually use it.
Yongkit
so far i have not experience any of the mentioned issue here honestly on the new driver but will update if i experience any weire encounter for sure.
kappak
mine is LG OLED, something to do with the instant game mode
Humster
If this one has 32GB VRAM they got a good chance can fight 5080 with games such as Indian Jones. If they smart, launch it at $999 and their market share grow even faster.
USD$999? Looks like thats whats gonna be the price once it hits the market. :flash:
-Synchronicity-
Assuming sg cards can continue to get the 9070 or xt at 899 and 999 respectively, their value in Singapore is about the same.
Xt is 11% more expensive for about 11-13% extra performance in 1440p which seems ok-ish.
Problem now is getting either card at MSRP and having enough stock.
vironix
The sapphire Pulse XT pretty cool. 60 odd Deg last night playing HD2 and Avowed
soreloser
Heres a link to the new 5070ti i just got, running at 3100Mhz@0,935V.
Has memory junction temperature at 50-54C and playing cyberpunk at 230W. I'd say the amd junction temps are much higher than the nvidia ones
Yongkit
https://www.hwinfo.com/forum/thread...emp-missing-3rd-fan-speed-summary-info.10306/
NVIDIA has removed “Hot Spot” sensor data from GeForce RTX 50 GPUs
https://videocardz.com/pixel/nvidia-has-removed-hot-spot-sensor-data-from-geforce-rtx-50-gpus
Very good for your gpu so no worry on your hotspot
soreloser
ya but thats GPU die, not the memory junction temps. Unless i'm mistaken, the 9070XT memory junction temps run at 90C while gaming and assuming that they use the sensor in the same way, the nvidia one seems to be much cooler
Yongkit
yeah much cooler so there is no need to worry on nvidia gpu.
from hwinfo noticed you didnt disable igpu, and also your presentmon show high CPU busy reading ?
are you able to take some screenshot like this?
