deathan9el
Honorary Mentor
- Jun 27, 2005
blow liao the dust go where
I bought from Taobao $70. It's under another brand.The top ranked Wolfbox MF
The top ranked Wolfbox MF100 now on sale on Lazada @$89. I just ordered one
I'm still using this.Last time Hardware Clinic all raving about this:
Blow dust into the air. On air purifier. Hahahawhats the point of blowing dust from one place to another. Quite a lame product
Too loud to be practical. You need to do deep cleaning first then use this to maintain. All the blowers cant remove layer of dust one.Last time Hardware Clinic all raving about this:
Try try for $57, should be more powerful than my Nitecore blower.
The ear can be exposed to short periods of sound in excess of 120 dB without permanent harm — albeit with discomfort and possibly pain — but long term exposure to sound levels over 85 dB(A) can cause permanent hearing loss.
https://en.wikipedia.org/wiki/Noise-induced_hearing_loss
mini blower battery cannot last that longcan use to blow dry car bo?
have both the mini duster and makita cordless blower
mini duster battery don't last too long 10mins?, small and handy for small compartment eg car dashboard, slim vents
makita blower need 2 batteries to blow dry car after wash
thought of getting a real petrol leaf blower to vacuum dry leaves for compost but found out its really damn LOUD, will rock whole neighbourhood lol
黑橙X3-M(显示屏) 8000毫安 +吸尘嘴19.8*4.5*17CM RMB 145
comes with 2 nozzles for blow or vacuum
from 1688.com, can use taobao password to login, need freight forwarder
expensive items best to buy from 1688, many taobao sellers markup and dropship from there
There is something called a "maid"Not really useful one. Can't blow off dust once it has settled. My more advanced duster is collecting dust LOL. I use sticky goop instead.
i had this, very noisy and need blow outside of house if not the dust just gets recirculated in the area. Intake suction below have to clean the sponge if not will choke..Last time Hardware Clinic all raving about this:
